gas fuel with glo plug no ignition
Reply
Old 06-25-2005, 04:15 PM
  #151
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: gas fuel with glo plug no ignition
If you replace that muffler, or take it apart and gut it and braze in two 1/2 or 9/16" i.d. tubes for outlets, you will gain a good bit of power.
AV8TOR
av8tor1977 is offline
Old 06-27-2005, 01:05 AM
  #152
davewallace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
The WT-499 is only a 11.11mm carb. The same size Homelite uses on a 33cc and a new or modified muffler would help. Many Homelite 45cc comes with a 14mm Zama or 13.49mm Walbro carb.
Dave
davewallace is offline
Old 06-27-2005, 05:59 PM
  #153
Fishmasterdan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave or Anyone else that wants to comment;
I see that the carb is smaller but it lets enough fuel to pass through to run on mentanol/oil. What carb would you recommend?
I notice at full throttle the fuel wants to spit out the front of the carb. ? What do think would help with that. I was going to order a new muffler but a friend is making me one out of aluminum diamond plate (for a cool factor ). I think I need one of those tubes that stick out the top of the carb?
Fishmasterdan is offline
Old 06-28-2005, 04:49 PM
  #154
RysiuM
RysiuM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It took me a while to read all pages
Now back to the post #1 - Aero-nut was running his 18cc on regular gas/oil (50:1) mixture with on-board glow. I understood, when glow plug was powered all the time he got good max rpm and steady idle. Is it right?
If so, does it mean, that if I replace the spark pug with glow plug (with adpater) and run 1.2V battery to it I can use the engine like the regular ignition-driven engine on regular gas fuel? If so, it may be worth just use it like that. 1.2V NiMh battery for a couple flights for sure weights less than any ignition module (4000mAh is less then 1.5oz). Mo hassle with mixing chemicals and messing with carb. That would be the lightest gas engine ever
So let me ask again the question: How will the regular 18cc - 33cc weed eater engine perform on regular gas mixture (no additions except 2.5% oil) with glow plug powered by battery all the time?
RysiuM
RysiuM is offline
Old 06-28-2005, 05:58 PM
  #155
Fishmasterdan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried it and it doesnt work to well. The engine does not run very good, I belive it is because it is firing way to soon. But if you change to methanol/oil mixture and a different/modified carb it works good.
That is what I found out but everyone seems to have a different opinion.
Old 07-03-2005, 08:35 PM
  #156
RysiuM
RysiuM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Fishmasterdan
I tried it and it doesn't work to well. The engine does not run very good, I belive it is because it is firing way to soon....
Maybe you didn't try hard enough.
Yesterday I went to Home Depot where I bought brand new Champion plug. After abusing it for a while with big vise I got all stuff out leaving just the case. Then I work a little on my lathe creating an aluminum plug that I tapped 1/4-32 for glow plug. Finally I got glow plug adapter that cost me $1.75 (Champion plug from Home Depot) and some time in my garage.
I found some old glow plug that I didn't use any more as it lost all platinum due to running glow engine to lean. It still glows when connected to 1.2V tho.
So I took out my Poulan 25cc I converted lately, changed the spark plug with glow plug and fired it up. Glow plug was connected to two AA type NiMh (RAYOVAC 1800maH each - yest this cheap stuff from Wall Mart) parallel (glow plug takes about 2.2A).
I kept glow plug powered all the time. Engine fired up like it used to on spark ignition and just run. I didn't even change the carb setting. Engine was idling steady up to 1600 rpm with normal transition to full power at 7400 rpm [X(] - it is 200 more than with spark ignition. I played with throttle running the engine total about 5 minutes. I didn't notice any problems.
I need to point it out: I run regular gasoline mixture: 1:30 Motul mixed with 93oct. pump gas (Chevron). No other additions, no methanol, no acethon - just gas station stuff.
Now I am very confused. If I remove spark ignition I will loose 1 lb and for on-board glow I will add 2 oz (one battery is 1 oz). 3600mAh will be enough for 90 minutes of flying. That's something new the lightest gas engine ever
RysiuM
ID:	293298   Click image for larger version
ID:	293299   Click image for larger version
RysiuM is offline
Old 07-03-2005, 11:26 PM
  #157
davewallace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Fishmasterdan,
The chain saw engine has higher compression then the trimmers, which may account for varied success with straight gas. The small WT-499 and restricted muffler would account for low RPM. If you could lower the compression you may do better on gas with stock carb. Removing material from the combustion chamber is about the only way to lower compression. Shaving material off the piston crown would advance timing, which is decent now.
Dave
Old 07-04-2005, 07:20 AM
  #158
FenceMagnet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Shaving material off the piston crown would advance timing"
Huh ???????????[X(][]
FenceMagnet is offline
Old 07-04-2005, 07:46 AM
  #159
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you lower the top edge of piston the intake port opens sooner!!!!! I would say....it does indeed change the timing. But if it runs better...who cares!!!! Regards Capt,n
captinjohn is offline
Old 07-04-2005, 10:31 AM
  #160
RysiuM
RysiuM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys, quick question - I think it is the rigt place to ask.
This thread started about running gas engine on gas fuel with glow ignition. Then for 7 pages the discussion went about different fuel mixtures. I did my experiment with the original setup witout mixing special fuel - I just run the engine the same way aero-nut run his engine almost 2 years ago. I did confirm, that my engine run just fine when glow plug was powered all the time. Any one tried the same?
I tried to run it without battery attached and it was running very rough missing often. On iddle it died when battary was disconnected. I also tried to start it by hand but I was not able to crank it fas enoug to go through the second compression after the first 'puff'.
I checked the glow plug after 10 minutes of runniong and it was clean and shiny.
Aero-nut run his weedeater 18cc, I run my poulan weedeater 25cc. Did anyone try this experiment on other engines or maybe can confirm the resul on the same engines?
I don't really care 'why' it's running. As long as it runs flawlesly I'm happy. And I don't need to mix special fuel or pay big bucks for fancy ignition systems. I am talking about the 25cc gas engine turning 16x8 MA 7400 rpm on stock muffler eating regular gasoline with the rate 1/2oz per minute, and weights 38 oz (including muffler, mount and on board battery) and cost me less than 40 USD.
RysiuM
RysiuM is offline
Old 07-04-2005, 11:04 AM
  #161
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Uh, whoops...
Shaving the piston crown will not change the intake timing, it will change the exhaust timing. Also, lowering the compression will not change the ignition timing unless it is operating as a glow engine. In that case, it would retard the ignition timing, as the engine would reach the pressure sufficient for "auto ignition" later. In engines that have a squish band step in the cylinder head area, machining this out will decrease compression without modifying the piston.
AV8TOR
Old 07-04-2005, 10:08 PM
  #162
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ment to say transfer ports...but ooops may be wromg there too!!! Ha. Getting "old I guess" Capt,n[:-]
Old 07-04-2005, 11:27 PM
  #163
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, it will change the transfer port timing too!
AV8TOR
Old 07-05-2005, 12:27 AM
  #164
davewallace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fence magnet,
The idea is that chain saws arn't running well on gas with a glow plug ignition because they may have too much compression. This causes combustion to happen early and results in rough running. With glow plug and gas the only way to control ignition timing is with compression. We need to lower compression by removing material from the combustion chamber, because shaving the piston would change port timing. We can't raise the cylinder because it is one peice with the crankcase. Anyway I think that the poor running of saws on gas/glow is excess compression.
Dave
Old 07-05-2005, 05:47 PM
  #165
RysiuM
RysiuM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: davewallace
Maybe by lowering the temperature of the glow plug will change the timing. Actually I was thinking of adding a regulated resistor to adjust the current and temperature. This should aadjust the timing for different type of fuel.
RysiuM
RysiuM is offline
Old 07-05-2005, 10:30 PM
  #166
wvarn1957
wvarn1957's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In my original test runs I found that varying the amperage on the plug had little effect except at 3000 rpm and below. See Post # 22 this thread.
wvarn1957 is offline
Old 07-05-2005, 11:36 PM
  #167
treecutter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glow fuel manufacturers have been adding oil to the fuel to delay ignition for years. It may be an option for you.
treecutter is offline
Old 07-06-2005, 12:01 AM
  #168
Rupurt
Rupurt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe you could make a glow adapter that can screw in or out to adjust compression like the diesel. I would do it but I for some reason don't have a 21 tooth gear for cutting the 1.25mm(it is 14x1.25 isn't it) thread and don't have the money for it right now.
Rupurt is offline
Old 07-06-2005, 09:26 AM
  #169
wvarn1957
wvarn1957's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rupurt,
If you have one of the Chinese Mini lathes from Harbor Freight, Enco or Grizzly you can use the following to get the 1.25mm pitch:
A-35, B-40, C-45, D-50 gives 1.2502pitch with a % error of 0.0125
Old 07-06-2005, 09:37 AM
  #170
tkg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several of the glow plug makers have cold and hot plugs. Seems to me that Rossi has a range of about 5 plugs
tkg is offline
Old 07-08-2005, 10:57 AM
  #171
RysiuM
RysiuM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another update on gas fuel, glo plug no ignition.
Quote:
ORIGINAL: wvarn1957
I think I can confirm that. I run the en\gine again (glow plug powered all the time, 93 Chevron gasoline mixed 1:30 with Motul oil - no methanol added). The engne run very stable 7400 rpm max (MA 16x8 Clasic) idling at 1600 rpm with very good transition. After a couple minutes it started to miss and eventually died. Then I couldn't start it again. I thought the glow plug went bed so I checked it. I found glow plug still in excellent shape but was not glowing orange, but rather dark red. The reason - glow battery died on me. I put a new battery and everything went to normal. Engine started after a few turns and run like usuall. I run it for another couple minutes without any problems.
Conclusion:
1. After total 20 minutes of runing I didn't notice any wear on engine nor glow plug.
2. Current on the glow really doesn't matter. Engine fires when it wants to, but at least my Poulan 25 wants to fire at the right time.
3. When glow plug is to cold engine just dies.
I'm not going to abuse test my engine any more, as I need it as it is (magneto ignition) for the plane I'm building. However I just bought another Poulan 25cc. This one I will cut to the bones making it as light as possible removing also magneto support and flywheel. Then I will test it as gasoline glow engine for longer time. If it works well, I will have the lightest gasoline setup ever: about 2.5 lb 25cc engine (including muffler, mount and on-board glow) runnign from 10cc fuel tank. Any 'brand name' of that size weights at least half pound more (and costs 10 times more ). The MVVS 1.6 I have weights 33 oz plus 5 oz muffler, + 2 oz radial mount plus 5 oz ignition plus 3 oz battery. = total 48 oz. It was the lightest gas setup I could ever come with so far.
RysiuM
RysiuM is offline
Old 07-08-2005, 12:24 PM
  #172
Antique
Antique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MY lightest G26 conversion so far is about 42 oz with muffler, battery prop bolt and nut, and ignition.....I haven't tried to see how far the fins can be cut down and still cool the engine
Antique is offline
Old 07-08-2005, 12:58 PM
  #173
RysiuM
RysiuM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: RCIGN1
Man, you must have cut it good - can you see the piston through the case
What ignition did you use?
RysiuM
RysiuM is offline
Old 07-10-2005, 10:15 AM
  #174
Rupurt
Rupurt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wvarn1957:
Thanks but its a Myford ml7, I should have a look and see if some of the other combinations are close enough. The parts for this machine are easy to get but really expensive around here(I have actually been advised that it may be cheaper to have the gear cut[:'(])
Rupurt is offline
Old 07-10-2005, 10:55 AM
  #175
Antique
Antique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The mag rotor, source coil, and rear crank extension for the rotor are all remover, about 12 oz....The ignition circuit weighs about 1 1/2 oz....There are 4 mounting lugs on the front of the case that are not used and can be cut off...The cylinder is square and can be slightly machines to lose a little more...The flat mounting plate on the rear can be removed and the engine mounted with the 3 5mm holes that held the plate on....I could use a lighter spark coil instead of the original Zenoah part and a 10 mm CM6 spark plug with a DA shielded cap to save a little more, have not tried that yet...An aftermarket aluminum muffler is lighter than the stock steel one....A 600 NiMh battery will run the ignition for over 2 hours, weighs 2 oz or less
Antique is offline
Reply
Display Modes
