If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Oct 2002
    Youngsville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Husqvarna or Poulan??
    I have the option of either converting a 40cc Husqvarna or a 42cc Poulan. Which should I convert? Does one have an advantage over the other? Which is easiest to convert? Thanks for all your help!
    -Zip
  2. #2
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Husqvarna or Poulan??
    Try to get a exploded view of thye Husky and see what you think. The Huskies I've seen in recent years are most ly plastic except for the running gear itself so there may not be much difference.
    If you havn't been doing conversions, the Poulan would be better because there is a lot of info on here about them and C-H sells the parts where you don't have to make them.
    Enjoy,
    Jim
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  3. #3
    Join Date
    Oct 2002
    Youngsville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah, I think that I am going to go with the Poulan. This was my original choice, but I have the opportunity to pick up a new 40cc Husqvarna saw for $90. I can get the 42cc Poulan for $120 (I think) from lawnstation.com. Seems to be more conversion parts available.
    BTW: do you think that a 46cc engine will be overkill for a dynaflite decathlon? Plane weighs approx 16-17lbs.
    -Zip
  4. #4
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It will have more power than needed but the physical size and weight between the 33, 42, and the 46 is the same. In the long term, the 46 would give you more flexibility for future use in other planes. You don't have to use it full throttle?
    Jim
    Original AMA #31261
  5. #5
    Join Date
    Jan 2002
    Ripon, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    zipnsplat, i have a Poulan 46 on my Super Decathlon. Yes it is probably overkill, but that's what the throttle is for. It will fly nice and slow or climb with unlimited vertical. I'm sure having fun with mine.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    www.tracyskyliners.com
  6. #6
    Volfy's Avatar
    Join Date
    Jan 2002
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DBF, very nice Decathlon there. That is a Dynaflight, right?
    The 46cc is the way to go, especially if you're keeping the magneto ignition. If you're buying from Lawnstation, the difference between 42 and 46 isn't all that much. Be sure to check their Ebay ads though.
    Si vis pacem, para bellum.
  7. #7
    Join Date
    Jan 2002
    Ripon, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Volfy, Yes, it is a Dynaflight.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
