Weedeater Featherlite Conversion
#51
IL
RE: Weedeater Featherlite Conversion
aero nut
Do you know what he pulled his ryobi 31 out of? I am on break from school and I have some time to do some biulding. I have had her sitting on the bench needing an engine for a while now. Every ones help on here has been much appreated.
Thanks To All
Baker
#52
Baker: Do you have a better address for chiefaircraft. all I get is bs run around sites that get you NO[:-] place good???? Thanks Capt,n
#53
Just started my conversion. Its a homelite 25cc short shaft. Im going to test it out when my parts from wacker eng. come in this week. I will tell yall about it and get some picks to post later.
#55
I pulled the engine out of a Ryobi blower< these have the lonh shaft engine and seem to put more rpms than the weed cutter, it's just my guess, you can buy the blower from Harbor Freight at $59.95
#56
CA
i have a ultimate 120 biplane and im looking for a weed eater or blower engine to put in it. what size and make should i use i was told a 25cc poulan ?????/ i just dont know help me
#57
My Feedback: (27)
CA
Echo 23.6cc Or Toro 25cc.
Both are great engines turn a 16 x 8 prop 9000rpm with a little work.
The Echo can be had for free is you go begging at small engine repair shops.
I've collecter about 40 of them and 40% of those the piston and cylinder were in great shape.
The Toro can still be had at E*ay for $40.00 or less bran new.
Run them on Gas/Glow and never look back.
#59
hello everyone.i have a featherlite 25cc weedeatermotor that i am converting to fly my super decathlon.im having tuning issues with this engine,as the needle valves are right behind the prop. is there a carb that i can purchase that will have the needle valves out of harms way. im running an 18by8 prop.if anyone has any info or away to get it tuned your responses will be greatly appreciated. thanks. BANDIT 21
#61
My Feedback: (13)
OR
those featherlite engines have very mild port timing, an 18x8 prop is going to be too big to get it in a happy point, I would go with a 16x6 or 16x8 myself.
are you using a larger carb? I'll try to look over what I have and see if any would work on one of those.
#63
My Feedback: (13)
OR
the homelite? I have a couple I've been meaning to mess with, the only hard part looks like mounting with the angled backplate it brings a challenge.
#64
They do look challenging with the way the crank case is made. I just have never seen a 26cc conversion with this engine.
Larry K
Larry K
#65
CA
ORIGINAL: Live Wire
Larry K
Larry K
#66
My Feedback: (51)
I have a Featherlite 18cc and a 22 cc,a least that's what's on the trimmer plate.They both have spring mufflers. I also know a guy who got a few 25cc from a salvage yard and would sell them.Would the Featherlite 25 cc with bolt on muffler be a better engine to convert than the Homelite 25 cc ?
#67
In reality, the Weedeater engines are very low quality, and low power. Better to go with almost any other engine in my opinion. I repair lots of yard equipment, and most of the time the Weedeater products aren't worth trying to save...
A Homelite would weigh more, but be a far better engine. Better yet would be an Echo.
AV8TOR
AV8TOR
#68
ORIGINAL: av8tor1977
Capn John... Here ya go: http://www.chiefaircraft.com/cgi-bin...els/Model.html
AV8TOR
AV8TOR
