Opensource CDI ignition
#151
RE: Opensource CDI ignition
ORIGINAL: hogboy
Hi all,
I've downloaded the schematics and pcb layouts from the GOMPY site and constructed it. CDI works well on the bench in test hi and lo modes and with magnet mounted to an electric flywheel the hall sensor fires the circuit well also. Can any one help though with the rotten excel spreadsheet. I've done everything as listed on this post regarding the ADD INNS for excel and still get the DEC@HEX macro problem. I would now like to be able to manipulate the advance curves but can't until I can get spreadsheet working. Also better way of contructing transformer is to use a split ferrite core and bobbin. Wind on 16meters of .2mm, 20 turns of .5mm and 10 turns of .2mm. Look forward to any positive responses to excel problem.
Hi all,
I am also new to this forum and trying to build the CDI too. The excel sheet has an error on the command DEC to HEX. The solution from lumpylumpy is given below.
Could you give some more information on your Transformer, and some specs on the core (core size, type, producer etc)??
Maku.
Hi,i had problems with the exel sheets too,have instaled office severel times,instaled all addins and still not worked! then i did a little research and found out that there is a little error in the formulas calculating the lines for the asm. ; this is how it should loke like =IF(B16<$D$8,CONCATENATE(" ",$E$14,DEC2HEX(D16),$E$15,$A$142,ROUND(D16/10,1),$A$149,INT(B16),$B$14))
and this is how it loked originaly =IF(B40<$D$8,IF(D40>10,CONCATENATE(" ",$E$14,DECHEX(D40,2),$E$15,$A$142,TRUNC(D40/10,1),$A$149,INT(B40),$B$14),CONCATENATE(" ",$E$14,DECHEX(D40),$E$15,$A$142,ROUND(D40/10,1),$A$149,INT(B40),$B$14)),$E$16)
i have deleted a portion of the formula,and where it writes dechex i have replaced it with de2hex,as you could notice in the formula! you have to have the next addins instelled:anallysis toll pack and solver add-in!!!!!!!
you copy the formula in to the first line off the exel (cell e16) and press enter;after that copy/paste on each line until finsh(do not paste severel lines at once, one line at a time so you dont have to modify the formula!!!!)
this is made for the exel map 42 ;you can do the same with the other exel maps,but the formulas not the same! so be careful what you delete from the formula!!!
I hope it helps you,and i did not write it two complicated!I am not so good at english.
rpm adv. nr loops lines to insert into asm.
1,010 6.0 50 retlw 31h ;5ms 1010rpm 1,010 6.0
1,017 6.3 49 retlw 30h ;4.9ms 1016rpm 1,017 6.3
1,024 6.5 48 retlw 2Fh ;4.8ms 1023rpm 1,024 6.5
1,031 6.8 47 retlw 2Fh ;4.7ms 1030rpm 1,031 6.8
1,038 7.0 46 retlw 2Eh ;4.6ms 1038rpm 1,038 7.0
1,045 7.3 46 retlw 2Dh ;4.6ms 1045rpm 1,045 7.3
1,053 7.6 45 retlw 2Dh ;4.5ms 1052rpm 1,053 7.6
this is how it should look like.
Regard ,Zoli.
#152
It is a good thing some one know how to read that. lol....
I was thinking of trying to make me one but as I read on I does not look to be a ez thing to do..
I will have to do some more reading.
Paul
Paul
#155
ORIGINAL: acgeorge
BCMA has them for $85 w/auto advance.
...If you run electronic ignition Radio Interference is always a possibility. If you encounter this problem here are some ways to help reduce or eliminate this problem....
If you are still experiencing problems, here are some more extreme measures:
· Wrap your ignition module with Aluminum Foil.
· If your ignition module is mounted on your firewall, apply HVAC foil ducting tape to the firewall.
· If your ignition module is inside a compartment, line the compartment with either Aluminum foil or HVAC foil ducting tape.
· Upgrade to a PCM type radio system.
#157
BigBoat, is it possible that you have an error on your web page and that when one clicks on the incircuitprogramming the small pcb layout comes up?
Yoram
Yoram
#159
BigBoat, if you go to your page http://www.modelbouw.gompy.net/cdi/cdi.htm the "Layout small PCB" and the "Layout small PCB for incircuitprogramming" comes up the same. Didn't you had a layout for a programmer or was it only a figment of my imagination? I don't mean the link to a programmer that you have on the new cdi page.
Yoram
Yoram
#164
Nothing.....you don't need it anymore if you gone use a prop.
You have to put somewhere a small magnet, but not into the flywheel becourse he is magnetic too.
The hallsensor must be placed about 40 degrease BTDC.
#165
one of the things Im trying to do is take off the big fly wheel.. It will not fit under the cowl I was thinking of training the fly wheel down and put the magnet in it. I just do not know if I will have probs with it if I do that..
#166
The flywheel is not only for the ignition, but it helps also the engine a littlebit with the rotation.
The crank only itn't enough to let spin the engine, he needs also the (rotation) weight of the flywheel.
The prop is taken over the (rotation) function of the flywheel.
#168
What I do is use a hole cutter in a drill press and cut out the center of the flywheel. Takes only about 3 min. Then I take and place the center of the flywheel and place it on a mandrel in metal lathe and cut to shape. You can add your magnet for the pick-up in a small hole drilled in hub. Good Luck......Capt,n
#169
Now that is the info I was looking for... I have not make a cdi yet Im still in the studding part of it.. It does not look that hard to do but well you know how it is lol
Paul
Paul
#170
I have all the components, now I just need to etch the PCB and wind the coils. I agree that winding a toroid is a royal pain in the behind. Does anyone have a source for E cores and coil formers? I have a CNC coil winder so as long as I can get a hold of the formers, winding is a breeze. Maplins in the UK sell Velleman kits but NOT the FLPS
Michael
Michael
#172
OH
All you that are building the CDI please post on how well your engine runs. Also anybody who is interested, I slightly redesigned the above CDI project. I am using the TI MSP-430 micro-controller IC. This is so much easier to control your auto advance. Just a P.C /laptop w/USB port running hyperterminal allows you to change your auto advance timing settings in Flash Memory. Also there are no limits on what else you can dream up.
Derek.
Derek.
#173
OH
Derek4210,
Can you post the code for that microcontroller? I am a relative newbie with PIC and have no experience with the TI product. I also live pretty close to you. PM, if you want to discuss.
John
John
#174
Try following link. I received 3 pcs two weeks ago. $5.99 / each
http://www.hobbyengineering.com/H1958.html
#175
Beware........not all coils can handle the high rpm......you need >15.000 rpm for a stock Zenoah.
Only weedeathers running slowly until 10.000 rpm.
