Super Teger 32500 to gas?
My Feedback: (16)
RE: Super Teger 32500 to gas?
[*] The glow fuel carbs work terrible on gasoline. They are too sensitive.
[*] You have to run a higher oil content in your gasoline because of the bushed connecting rod.
[*] People have converted the rods to needle bearings but then the crankpin fail prematurly
[*] The best deal is to run ignition and keep the glow fuel. They seem to run real smoothly.
[*] Power is down noticably with gasoline compared to glow fuel.[ul]
[/ul]
[/ul]
FL
"You have to run a higher oil content in your gasoline because of the bushed connecting rod.
People have converted the rods to needle bearings but then the crankpin fail prematurly "
if you soften the crankpin a bit with a torch, you can turn it down and press on the appropriate inner race for the needle baring.... then it holds up fine... you can run 50:1 mix
"Power is down noticably with gasoline compared to glow fuel."
once the oil mix is down, and a nice walbro is mounted up front, the power comes back.... my ST3000 turns within 150 rpm on gas with an 18-6 now as compared to 10% glow fuel....
Jim
Jim
My Feedback: (7)
Thanks guys for the input. My understanding is the Moki is aconverted to a MVVS and now to the Evo line of motors. but they want a fortune for these. Thanks Rich
I Have comvert some supertigres
This is my expor quality conversions This is a SUpertigre STM SE
[youtube]http://www.youtube.com/watch?v=BwqOlM3stPA[/youtube]
Dear Rich
I use a walbro 15 mm ventury
Today I finish and tested a BGX-1 35cc, with modified walbro carb 15mm
This new walbro can work perfect in 4 strokes and in 2 strokes no need pump prezurizacion from backplate
I move up and doun fuel tank with 2ft long tubind in idle and in full trhotle and rpm dont varies
Will upload video later
I dont remeber exactly but if Im ok the walbro was a WT 624
You can use any walbro I usesd to a 13mm give same performace.
Regards MAx
Regards MAx
