If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 7 123 ... LastLast
Results 1 to 25 of 151
  1. #1
    Join Date
    Dec 2004
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Stihl 65cc 4-mix on 30% Edge
    Here are a few pics of my KMP 30% Edge on maiden flight today...
    Stihl 65cc four stroke 50:1 mix
    22x10 prop
    (5) 200 oz digital hi torque (Tower Pro) servos
    (2) Futaba 3004 throttle and choke
    7 channel Futaba RX
    2500 mah nimh battery
    This engine sounds AWESOME!!! Especially at lower RPMs, and has tons of torque. I'm still breaking her in so I was afraid to do any hover type maneuvers, but this thing rolls very axially and flies pattern very well. May try bigger prop, any suggestions other than 24x10?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	488834   Click image for larger version.
ID:	488835   Click image for larger version.
  2. #2
    Join Date
    Jan 2005
    San Antonio, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Stihl 65cc 4-mix on 30% Edge
    Tripp,
    Could we get some pictures without the cowl? What is the rpm with the 22x10? Too many questions. Any further details would be great.
    Thanks, Dave
    Every day above ground is a good day.
  3. #3
    KenLambert's Avatar
    Join Date
    Dec 2001
    Livingston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    here are some pics
ID:	489069   Click image for larger version.
ID:	489070   Click image for larger version.
    website
    www.lambertsrc.com
    Super Tiger conversions
    thanks Kenneth
  4. #4
    subarubrat's Avatar
    Join Date
    Apr 2005
    Remington, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Any chance of capturing the sound? That is a fantastic result, finally a 4 stroke conversion flying an aerobat. Allot of these competition guys are going nuts over noise, what will win out, the result of the conversion engine or the prestige of having the proper popular engine?
    Like classic video games and pinball, check out www.retrogamingroundup.com
  5. #5
    Join Date
    Jan 2005
    San Antonio, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ken,
    Great solution for a lefthanded engine. Nice pictures.
    Dave
  6. #6
    KenLambert's Avatar
    Join Date
    Dec 2001
    Livingston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    that is the engine that is on tripps plane.
    website
    www.lambertsrc.com
    thanks Kenneth
  7. #7
    Join Date
    Dec 2004
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Ken,
    I love this engine, thanks again! I have since cut some of the unecessary aluminum off the engine so this thing looks like nothing but cylinder and carb when the muffler is off I wish I could capture the sound of her but I dont have a camcorder.
    I stihl haven't tached the engine with the 22x10 and honestly it doesn't appear to be turning all that fast, but it turns it with such authority I think I could even go a little larger, maybe...
    (note the .095 weedeater line used for choke and throttle= no glitches)
    12 volts wouldn't think about cranking her so I had to get a 24 volt Sullivan. Now it starts so fast its almost scary. I am curious about battery ignition but don't know if I have many options being 4 stroke, plus the mag seems to work pretty well.
    Oh btw, I am using lots of expo on throttle b/c of low end power, almost ran me off the runway. I think I just need to adjust linkage at servo to adjust travel, and reduce ATV on Tx.
    Engine is off again now as I'm cutting firewall back two inches to fit cowl properly
    Here are some pics, one with engine still mounted. was considering Zenoah G62 but since this one is a keeper, the firewall is getting cut and the Stihl is going back on...[>:]
ID:	489286   Click image for larger version.
ID:	489287   Click image for larger version.
ID:	489288   Click image for larger version.
  8. #8
    Join Date
    Jan 2002
    Hesperia Michigan, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What is the big hose going to bottom of carb for? How about vibration at different speeds? I bet the sound is great. The 4 strokes have a longer push on the piston...making more torque. The windows in the cylinder on a 2 stroke....cause a loss of that push. Capt,n
    I never met a engine I did not like !
    6/8/2015 http://www.lambertsrc.com/
    http://pure-gas.org/about
  9. #9
    Join Date
    Jan 2002
    Ringgold, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    For all the world, that looks like a PCV setup (positive crankcase ventilation) to me. I can see a lot of places to reduce weight on that engine.
    How much did the engine cost? TIA
    \"Practice makes prefect\"
    Saito Club Member #52
  10. #10
    Join Date
    Dec 2004
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the hose is an impulse line that uses crankcase pressure to work the fuel pump on the carb.
    Vibration is not bad, but a slightly high idle helps, epoxy and tri stock are your friends.
    accelerates VERY hard but no blistering top end like the 2 strokes...
    Cap'n, I've always liked your quote, and you'll find it holds true with this one.
  11. #11
    Join Date
    Jun 2006
    Grand Forks, ND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    From the looks of the ignition setup, there's no timing system other than fire-every-revolution, so there's no reason you couldn't use electronic ignition. I'm sure there would be a nice gain if you used a spark advance as well.
    I imagine that hose comes from a difference source than a 2-cycle's fuel pump pulse, since a 4 stroke needs fuel every other rotation - even if there's no air intake the pump will still spurt out fuel as the throttle is still open
  12. #12
    Antique's Avatar
    Join Date
    Jul 2002
    Somewhere, DC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The hose comes from the crankcase just like a two stroke...There is just enough of a pulse to operate the carb...There is a misconception about the pump function in the carb, it just fills the cavity under the diaphragm, it can't pump fuel out of the carb..
    There is also a misconception about spark advance, the only engines I know of that benefits from more advance are the FPE engines that were set up at 18 degrees...
    Timing at 28 or 30 is the best, there is no noticeable change a few degrees one way or the other from there....Too much advance makes the engine miss, too little makes less power..
    RC Ignition
  13. #13
    Join Date
    Dec 2004
    Memphis, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ralph,
    weren't you running a walbro sdc80 on this engine with good results. I ended up using the stock carb and had to mix my choke and throttle servos together to close the choke just a hair at half throttle for max power. adjusted carb but did not help, turned high speed screw out until it fell out in my hand with engine running, and STILL was asking for more gas...
  14. #14
    Join Date
    Mar 2003
    Mill Spring, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    YES! electronic ignition is VERY possible. just talk to the nice folks at C & H ignitions & they'll build you one. actually, they've already done some conversions on that engine including electronic ignition.
    to the guy who was wondering about the "firing every stroke" factor... yes, the spark plug fires every stroke, but the valve train only introduces air/fuel mix every other stroke.
    the 'large hose' from the crankcase... it uses the crankcase pressure to 'supercharge' the engine so to speak. exact same principle as the YS 4 stroke engines. in fact, wouldn't surprise me at all if StihL didn't copy the YS design. they were the first to do this. 4 stroke heaven? would be if Saito & StihL would 'hook up' and design a super light weight, high compression, methanol powered version of this engine. then comes 80 & 90cc versions. weeeeeeee
    drdrain
  15. #15
    spiffymafied's Avatar
    Join Date
    Oct 2004
    Mansfield, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That is a nice looking engine. What would that have come out of? I'd like to find one.
  16. #16
    Join Date
    Nov 2005
    SuffolkSuffolk, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Stihl BR550 or BR600 backpack blower.
  17. #17
    DKjens's Avatar
    Join Date
    Feb 2002
    Pasadena, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: drdrain
    It doesn't look like this engine uses a supercharging principle. It looks like the carb is attached directly to the head. It is a brilliant idea though, to attach the carb via a reed valve to the crankcase, and then run an intake runner from the crankcase via another reed valve to the intake port. This would take care of lubricating the bottom end of the engine as well as pressurizing the intake mixture.
  18. #18
    Join Date
    Jun 2006
    Tuckerman, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tripp3d
    Do you go to the giant scale fly in at Hot Springs AR Oct, 12, 13 and 14. If so let me know so can be looking for you. I would like to see this set up.
  19. #19
    Join Date
    Jan 2003
    easthaven, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    has anybody tryed the 25cc? 4-mix ? thanks Erik
    erik58
  20. #20
    Join Date
    Jan 2003
    easthaven, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    erik58
  21. #21
    Join Date
    Mar 2003
    Mill Spring, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    check out the animation on StihL's website. it shows it clearer than I can explain it in words. but in the long run? they force feed the fuel air mix using the pulses from the crank case.
    drdrain
  22. #22
    DKjens's Avatar
    Join Date
    Feb 2002
    Pasadena, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    drdrain,
    I've been on stihlusa.com and have not found any animation or other that explains that their 4-strokes work that way. I know exactly the principle you are talking about, and I believe a European engine manufacturer made a 4-stroke using this principle. The particular engine in this thread does not look like it operates that way, I mean, the carb. is attached on the head, not the crankcase, and there is no visible manifold running from the crankcase to the head.
    Ig you have a link you can post, I'd be more than happy to look into it.
    DKjens
  23. #23
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  24. #24
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And for for the equivalent Shindaiwa C4 can be downloaded from here.
    http://www.t2500.com/downloads/index.html
  25. #25
    Join Date
    Mar 2003
    Mill Spring, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    there used to be a place on stihL's site where you could view an animation of the innerworkings of this engine while running. I got a good look at it about a week ago while at a friends' house. I was WRONG about the hose. it only operates the pump, just as tripp3d says. however, in the diagram, it shows the crankcase pressure being 'pumped' past the valve train, building pressure, then releasing into the intake valve. has anyone else seen this animation? past a link on here perhaps?
    drdrain
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
