Echo GT 1000
Echo GT 1000
How many cc is a Echo Gt 1000 string trimmer? Got it going today on 10% glow fuel. Seemed to run pretty good with no carb adjustments!!!!! Seems like the prop may be too small to me so I did not open it wide open yet!!! More to be done on it when I get a chance. Capt,n
AL
RE: Echo GT 1000
Capt,n,
That is a 16cc engine. I have one that I converted and ran it on gas with electronic ignition. From memory it would turn a 14 or 15 inch prop I think. Would go good in a smaller cub etc. Anyone want to buy it??
OH
RE: Echo GT 1000
hi, I have a Echo Gt 1000 and I'm starting to convert it for glow engine. What do you want for yours? You take PayPal? what have you done to it? what sieze is the engine shaft and what thread is it so I can oder a prop hub. What muffler you have on it and what engine mount you have? Chris
OH
RE: Echo GT 1000
Hi, Do you know the prop hub thread and sieze on you engine? Does anyone know were I could get a mount and prop hub? Could you post a picture of the rear mount for me, thanks
AL
RE: Echo GT 1000
If my memory is correct it was 8mm X 1.25. For the mount I made an aluminum plate or radial mount. Mounted it to the engine then to the firewall. I will look for a picture of mine.
My Feedback: (49)
AZ
RE: Echo GT 1000
heres a photo of mine and you can see the mount.Its 3/16ths aluminum,the xxxs are going to get cutout so it will be basiclly a tri-point mount.im using the three screws on back of engine to hold it on.The hub is one of some xtras i have.8x1.25.(1-1/2 inchs long.1 inch diameter at bottom and 1-1/4 inch at prop end.)ill send you PM.(had to edit,forgot pics first time.)
RE: Echo GT 1000
To save weight on most of my conversions, I just install studs in the backplate that slide through the firewall and have flat washers and nuts behind the firewall. It's a little less convenient having to reach in behind the firewall to install the washers and nuts, but it's lighter and saves having to make the mounting plate.
When I did my Echo 16cc, it flew a 10 lb. airplane ok at sea level, but was underpowered when I later moved to an altitude of 4500 feet. (This was on an aerobatic plane.) But this was before we invented "Gas/Glow". It would have more power and be lighter on Gas/Glow, and therefore more feasible, especially on a more floater type of airplane such as a Cub or Telemaster.
AV8TOR
AV8TOR
OH
RE: Echo GT 1000
Hay tim220225 , how do you get your motors so nice and clean looking? Look very good
Did you make the muffler?
I've noticed on some of your other post, (Poulan 25CC) you like the round motor mounts, any reason for that?
AL
RE: Echo GT 1000
Thanks for the compliments. No reason for the round mounts, just looks cleaner on some engines. Plus if I have the rotary table setup on the mill I just go with it. As for the consistent appearance of the engines I bead blast all the parts before I put the engine together. Didn't make the muffler. This one was from Ken Lambert as I recall. Also have some from Scott at Brillelli.
QC, CANADA
RE: Echo GT 1000
Hi, I just picked up one of these engine (16cc GT1000)
, the guy at the small engine shop didn't know how many cc's this one was and I really
wanted something more like 24-26 cc range. It looks good without too much wear, so my question is this, I want to put it on
a champion (cub type) that has 108" wingspan 15" chord (roughly 1600" sq.in. area) and the airframe weights aprox. 10-11 lbs
(no engine, no radio) so maybe 14-15lbs finished? I don't intend on doing much more than mild flying with this thing, think it's
worth converting?
One thing I do like is that it would fit completely inside the cowl , and can you guys tell me where I could get a prop hub
for it?
This would be my first conversion, hopefully I will end up with something that matches the craftmanship you guys are
showing, really beautiful stuff!
Thanks.
worth converting?
for it?
Thanks.
AL
RE: Echo GT 1000
I really think your new motor is too small. Look at the new H-9 Cub with the G-20, the plane is nowhere near as large as what you are doing and the engine is about 30% more displacement. I would look for a 23 or 26cc engine to convert. Good luck.
My Feedback: (49)
AZ
RE: Echo GT 1000
I would definatly say to small.There was a guy from Tuscon,south of me who was selling his engines from the same size cub and one other [plane] he had here on RCU.All 3 of them where no smaller than 22cc.He said they flew it good but that was it,so expect there wasnt a lot of reserve power or anything.The only thing you might have would be a powered glider but ypou might have to have a high start to assit in takeoffs.Now i dont know for sure,this is only from what ive read here.But i was going to put my 16cc echo on my 96 inch spook,it only weighs 7 lbs.But i thought against it and sold it a week ago because im going to put on my 24cc echo with cdi ign.I had a K&B 61 on it and i didnt like it.Flew it,but not just enough oomph.Especially in an emergency and i had one.Let a guy fly it and he stalled it close to the deck,i almost didnt recover[15feet before terra firma].Its only a 3 channel.
RE: Echo GT 1000
I got another engine to convert. It is a 25cc with good size ports. It had a small carb and that carb is going to be rplaced. I got so many irons in the fire right now...its going to set a few days....dogone it!!! Capt,n
