Super tiger 2300- gas
#77
RE: Super tiger 2300- gas
AV8TOR, Hey man you are doing it right. The airplanes you picked are "FUN" airplanes I woud say. Take Care my good Friend, John Capt,n...that is!
#78
ORIGINAL: KenLambert
Ruskin isn't very far from here 15-20 miles
#79
Well, I finally got to vist Ken Lambert. We sure had a great time talking about engines. The neat thing was I could see several types of engines apart and see how the ports...ect compared! He has built fixtures and special setups to machine the Tiger parts for conversion to gas. He spent a few hours giving me tips on all the details. Let me say it does take a skill and time to do a Supertiger conversion to gas using needle bearings.
I got to visit Ken one last time at his shop on the way back form a Jet fly-in at Lakeland Florida. If weather permits there is one more big-bird fly-in near here and Ken and I will be there. That should be a blast!!! Best Regards Capt,n
#80
My Feedback: (79)
Ken,
Are you still working with ST 2300 conversions? I have a 2300 I would like to run on Ignition with alky. I am interested in purchasing a hall sensor mount and drive hub with a magnet installed if you are still working with them. I am currently running an OS 7D carb with a cline reg. but would like to try ignition for a little more power. I am fine with glow fuel since I make my own and have alcohol (2) miles down the road from my house for $2.55 a gallon.
#82
Yes I am still doing engine conversions. I have the parts but will need your prop hub for the magnet
Have a bunch of ST parts.Do you want them? Just pay shiing and there yours.
Thanks BCCHI
#84
sounds good to me. Let me know what it cost
My shipping address for today is
Kenneth Lambert
c/o Galveston Bay RV resort # 7
10000 San Leon Dr
Dickinson, TX 77539
Don't give up on me I will get it done.I do not seem to get much done anymore.Turned winter here. Too cold to go search for parts in shed. Was -27 F last night.
BCCHI
Kenneth Lambert
10000 San Leon Dr
Dickinson, TX 77539
BCCHI
#86
My Feedback: (79)
I would like to purchase a timing ring for a Super Tigre 2300, but I do not need a carb adapter. Can you send a paypal invoice to [email protected]
Thanks, Ken
Thanks, Ken
#93
My Feedback: (79)
What about the (3) Rimfire's I have comming in the mail. If I can get a summer on a plug I will be just fine. I guess I can allways switch later on. When you drill and tap the head for the 10mm threads to fit the CM6 do you have to have to run a spacer with the compression washer to obtain the correct spacing.
#94
My Feedback: (107)
NO and NO on the compression ring and spacer , If you have already orderd the 1/4 x 32 plugs use them just make sure you have the plug wire fastened so it does not flop around , breakage is the most problem with the little plugs not wear . I have run some of them 2-3 years with no problems.
#95
Hi, Ken, I am in Florida again and just noticed this thread, I will PM or call you about you setting up a SuperTiger2300 too run on gas. I always wanted to do that. Take Care....I will get in touch. Capt,n John Hesperia MI..Now Aripeka FL
#98
My Feedback: (79)
Cool, what do you charge to install a hardened pin and needle bearings on the rod? And would that conversion hold up on glow fuel. I know that the webra bully and tartan ran needle bearings with alcohol and oil or normal glow. The only issue would be the added corosion factor.
But I could cut the fuel cost down, since the oil is my most expensive ingredient at 25.00 a gallon. My methanol costs 2.55 a gallon. You can email me at [email protected]
