Convert GMS 120 glow to Gas
Reply
Old 12-24-2007, 01:21 PM
  #101
borna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Convert GMS 120 glow to Gas
Hi AV8TOR,
Yes it does have the V groove. I'm going to switch the carb. I have another carb that doesn't have the grove so I'm going to give it a test with that.
Borna
borna is offline
Old 12-24-2007, 02:22 PM
  #102
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bet that will fix it. When putting the new carb on, check very carefully for any possible intake air leaks as well.
Good luck and let us know how it works,
Happy Holidays,
AV8TOR
av8tor1977 is offline
Old 01-18-2008, 08:24 AM
  #103
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How's the GMS working out? We haven't heard from you in a while and I am just curious. [8D][8D]
Jezmo is offline
Old 01-18-2008, 09:43 AM
  #104
borna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jezmo,
I got busy again with other stuff. Will try to do another test run either this week or next.
Borna
borna is offline
Old 01-18-2008, 07:05 PM
  #105
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK man, good luck with it.
Jezmo is offline
Old 04-11-2008, 08:09 PM
  #106
PlaneKrazee
PlaneKrazee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How's that GMS conversion working out?
PlaneKrazee is offline
Old 04-12-2008, 11:03 PM
  #107
borna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello all
Today I ran the GMS 120 on denatured alcohol bought from hardware store.
Initially I was trying to mix it with 2 cycle oil but didn’t mix well. Also tried mixing it with the Mobile syntactic motor oil and still didn’t mix.
Finally tried some caster oil and it mixed. Ran the engine with it and produced good strong RPM, however starting the engine with denatured alcohol wasn’t as easy as starting it with gasoline.
Of course I changed the carburetor from Walbro to original carb.
The thing I liked was no smoke or any bad smell of gas. I think that is what I want to run the engine with since I hate the smell of gas.
Now the question I have is what kind of oil is best to use with the denatured alcohol that mix well?
Beside the price, any disadvantage of running the engine on denatured alcohol vs gasoline?
Borna
borna is offline
Old 05-12-2008, 03:09 PM
  #108
lemac flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just finished a conversion to gas(petrol) gms 120 cdi ignition walbro wa110 carb qalso lowered the comp ratio ignition timing at 28 degrees btdc, runs great on a 16x6 prop it is now installed in a seagull yak 54 was wondering if you had any thoughts on performance
lemac flyer is offline
Old 05-12-2008, 06:40 PM
  #109
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several questions come to mind. Did you put needle bearings in the rod? What oil to fuel ratio are you using? I am also curious about lowering the C/R.
Borna, the oil's that work with methanol will work fine with ethanol. I understand there are some very fine oils available in Europe that we don't have access to here in the states. The best we have available is the oil that Coopers Fuels sells. PM Brian and he can give you a price and shipping info. I was running mine with Klotz when I was experimenting with Ethanol. (The Klotz that has both synthetic and castor, I forget the number)
Jezmo is offline
Old 05-26-2008, 05:34 PM
  #110
borna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, here is the latest news about my GMS. Today I did more testing with ethanol and caster oil as lubricant. I was getting good result and after about 10 mins, the engine stopped with a clicking sound. I noticed compression was lost so I know something went wrong. Tool the engine apart and noticed the piston ring broke. Luckily no damage to cylinder. The broken piece ended up in the crank area.
Question to those expert, what could have caused the ring to break? Not enough lubricant or ????
Borna
borna is offline
Old 05-26-2008, 08:15 PM
  #111
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The only thing that comes to mind is detonation. The ring will survive with ratios down to 100 to 1 or better. It's usually the piston that scuffs when the oil gets too low in ratio. Where was the timing set?
Jezmo is offline
Old 05-26-2008, 09:58 PM
  #112
borna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jezmo,
The timing is set to 28 BTDC.
Borna
borna is offline
Old 05-26-2008, 11:55 PM
  #113
tkg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is the ring pinned?? If it was, maybe you got the piston in backwards and the ring gap caught a port.
tkg is offline
Old 05-27-2008, 08:08 AM
  #114
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the timing was at 28 btdc then I agree with Terry (tkg) on the ring catching a port. Only other thing that makes sense.
Jezmo is offline
Old 05-27-2008, 08:33 AM
  #115
borna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Humm that could have been the cause. Also what do you mean by "maybe you got the piston in backwards"? Anyway I'm going to order the ring from Tower Hobbies, but want to make sure when I put it in, I put it in correctly this time, if this is because I didn't install the ring correctly the first time.
Thanks again
borna is offline
Old 05-27-2008, 09:39 AM
  #116
tkg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A ring is pinned so that the end gap is ALWAYS on a solid part of the cylinder wall. If you installed the piston turned 180 degrees when you reinstalled it, then maybe the end of the ring was passing a port opening and finally caught.
tkg is offline
Old 06-02-2009, 06:13 PM
  #117
borna
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW, after waitting for over a year, finally Tower hobbies has the ring in stock. I just order it today so soon I can do more testing.
Borna
borna is offline
Old 06-03-2009, 01:20 AM
  #118
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great, let us know how it runs when you get it going again.[8D]
Jezmo is offline
Old 06-05-2009, 09:03 PM
  #119
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: borna
Borna
Not sure....but I think you could have got the piston ring right away and maybe less $$$ from Frank Bowman. Good luck Capt,n
captinjohn is offline
Old 06-15-2009, 08:35 PM
  #120
trumpetman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just to give you a reference for power.  I have a GMS 1.2 on glow and I am getting 9000 rpm on am APC 16/6 and the same
on a 15\8 APC.  this may not be as good as some as I am at 5000 feet in Denver, but it seems pretty good.
Jack
trumpetman is offline
Old 06-17-2009, 04:24 PM
  #121
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this is all very interesting !! and 9570seams to bepretty good considering we are running our AX 46right at12,000 on 15%,,
borna,, if you do feel you need more power you could buy a gallonof say 30% heli fuel and add some toeach gallon ofgasoline, mixing this way a gallon of heli fuel should last you a few years..
Gass/Glow mix how-to,,
with the ignition I myself would be concerned about weight unless the plane was tail heavy to beginwith,, Iwould like to do the crank bearing mod and burn the Gasoline/Glow Mix with a 4st Plug and not use the ignition, I got to get my 4-Star 60 back together LOL
Jim
the Wasp is offline
Old 06-25-2009, 06:11 PM
  #122
miker42
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
I am converting a os 160.
What did you set the timing at befor TDC ?
Alos did you try to use the glow fuel carb?
Thanks Mike
miker42 is offline
Old 06-25-2009, 06:18 PM
  #123
miker42
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Thanks Mike
miker42 is offline
Old 06-25-2009, 10:15 PM
  #124
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: borna
Borna
I sure would like to see a photo of that broken piston ring! The broken part must have traveled back to crankcase through a port. If not ....seems like a scratched cylinder wall would be for certain. If no damage....you are one lucky guy!!! Capt,n
Old 06-26-2009, 04:38 PM
  #125
miker42
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guy
Where did you get the spark plug wire.
I have the rim fire plug and have it rigged up and it works but it may come off in the air.
Thanks Mike
miker42 is offline
Reply
Display Modes
