If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 6 FirstFirst ... 456
Results 126 to 149 of 149
  1. #126
    Join Date
    Nov 2008
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Convert GMS 120 glow to Gas
    [img][/img]
    Hi
    Check it out this is a OS 160.
    I have not put it on a plane yet but soon it will be on a plane.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1225312   Click image for larger version.
ID:	1225313   Click image for larger version.
  2. #127
    av8tor1977's Avatar
    Join Date
    May 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What is the line coming off the side of the crankcase? I am assuming it is a pressure pulse line for the fuel pump, but it doesn't seem to be hooked up properly at the carb. (Hard to tell from the pic.) Also, it appears to be a silicone line, which is a huge "No No" with gasoline. The gasoline will turn it to mush in a short time....
    AV8TOR
    If it is not SCARY, it is NO WHERE NEAR powerful enough!!
    All R/C planes have expiration dates---> It's just not printed on them anywhere!
    Just because it's not a good idea doesn't mean it won't be fun!
    Never underestimate my level of immaturity.
  3. #128
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    that spark plug connector reminds me of "RF CITY" Do you have a resistor in there?
    [img]{akamaiimageforum}/upfiles/449233/Nk27900.jpg[/img]
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  4. #129
    Join Date
    Jan 2002
    Hesperia Michigan, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you want a shielded cover for that small spark-plug, get in touch with Ralph at rcignition.com He did have them. Nice looking OSMax. What brand of oil and what % are you running in engine? Best Regards Capt,
    I never met a engine I did not like !
    6/8/2015 http://www.lambertsrc.com/
    http://pure-gas.org/about
  5. #130
    Join Date
    Nov 2008
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    That line goes to the carb adpter ti pump the carb.
    And I will change line.
  6. #131
    Jezmo's Avatar
    Join Date
    Jun 2006
    Spring, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice looking conversion Mike. Yes change the silicone hose for sure. My SuperTigre 90 also uses an adapter plate that has the pulse connection plumbed into it. Works very well. If you decide not to change to a fully shielded plug cap then do a VERY GOOD range check. Those little Rimfire plugs don't have a resister in them and without full shielding all the way to the plug base you can get some pretty bad RF interference as w8ye mentioned above.
    Spektrum DX8i, DA DLE SuperTigre OS FOX Saito Enya Jett TT: John 3:16
  7. #132
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: av8tor1977
    What is the line coming off the side of the crankcase? I am assuming it is a pressure pulse line for the fuel pump, but it doesn't seem to be hooked up properly at the carb. (Hard to tell from the pic.) Also, it appears to be a silicone line, which is a huge ''No No'' with gasoline. The gasoline will turn it to mush in a short time....
    AV8TOR
    Miker, As long as gas does not run through or collect in the silicone pulse line.....it may last a long time. On test stand...how is it seem to be doing...just curious. Capt,n P.S. Would like to hear more on how the OS Max runs. Thanks
  8. #133
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Miker, here is a photo of one type of sparkplug shield....there are others also. Capt,n
  9. #134
    av8tor1977's Avatar
    Join Date
    May 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Why would someone take a chance with a known improper fuel or pulse line? Good way to possibly lose an airplane if the engine quits at a bad time....
    AV8TOR
  10. #135
    Jezmo's Avatar
    Join Date
    Jun 2006
    Spring, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    AV8TOR
    I'm with ya on this one. Fuel line is way too cheap to take a chance.
  11. #136
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    AV8TOR
    AVATOR...Can you read the post??? TEST STAND...just to see what happens. OK WITH THAT?? OH my acking *****
  12. #137
    Join Date
    Nov 2008
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Capt,n
    Where can I get a shielded plug conector like that?
    I went to rcignition.com but could not find anything.
    Thanks Mike
  13. #138
    Join Date
    Jan 2002
    Riverton, WY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If the comments about the pump line were not made, what do you think the odds are that the engine would have installed in the plane that way.
    To many people have the attitude of what is the MINIMUM I can do and still fly my plane. The correct attitude should be What are ALL the things I can do to to my plane to keep it flying.
    Remember the RF signal is in MICRO volts and an engine that quits in a torque roll is breakfast food.....pancakes
    DO it right, DO IT the best you can and DO IT ONCE.......
    TKG
    Too much power is just about right.
  14. #139
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: miker42
    Hi Capt,n
    Thanks Mike
    http://www.ch-ignitions.com/#cat
    I couldn't find the Rimfire but if you call them they can fix you up
    Edited to correct the fact that I had answered a different post than I thought I was
    Original AMA #31261
  15. #140
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tkg
    I agree...do it best the first time....that is if your flying. If Miker is just testing his engine & ignition system, he can at least see what does NOT work on the ground. He may not have the proper fuel line for pulse connector on hand now. But by doing what I said he can at least continue testing on ground ...same as a test stand. Miker...take our advise an do not fly untill all the tips others gave you are taken care of. Have a helper when you fly that can land a airplane with a dead engine. I always flew every drop out of my airplanes in the old days and would glide in. It is good pratice...in case you have a dead engine. By the way, you will find out there are many things that can go bad all of a sudden...that is the odds!!! Good luck and let us know if you run into any trouble. Capt,n
  16. #141
    Join Date
    Nov 2008
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I didn't mean to cause all that about the line, I just put that line on to try the engine out, all the lines will be new when it goes in the plane
  17. #142
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Miker42, you did not cause all the replys about the pluse line, Oh and the ignition. We was just helping at the moment. It looks like to me with just a few postings you have made that you are doing very well and can already post photos (something a lot of people cannot do) so to me you are above average for a new person doing some pretty good research & testing already. Keep up the good work...and you did not cause a fuss at all. It was clear who caused any fuss. Capt,n
  18. #143
    av8tor1977's Avatar
    Join Date
    May 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sure was...
    AV8TOR
  19. #144
    Join Date
    Feb 2003
    Boynton Beach, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I can see some interesting pictures and lots of posting. I haven't worked on GMS yet since I'm busy building a model engine from scratch which is taking away my interest away from GMS engine. But that doesn't mean I'm not going to work on it.
    Captin, I don't have a picture of the broken ring and I have already replaced it with the new ring. However no damage to any thing when the ring broke. As you said I guess I was lucky
    Miker, are you using needle bearing for the connecting rod? Have you tested the engine yet?
    Borna
  20. #145
    Join Date
    Nov 2008
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    No I did not change the bearing , I have ran the engine but I am waiting on a plane I have order.
    I will post when I get it in the air with some pixs
    Thanks Miker
  21. #146
    Join Date
    Nov 2008
    Columbus, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Capt,n
    I called ch ignition and they sent me the cap I needed and I have instaled and it works grate
    Thanks Miker
  22. #147
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    miker42, when helping others, one is in turn helping yourself! I am glad the ignition is working good. The CH guys are good for exact ignition parts one may need. Best Regards Capt,n
  23. #148
    Join Date
    Nov 2006
    diamond creek, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good Morning all from Australia.
    I have been reading alot of threads regarding conversions, but wanted something smaller.
    Back in 2007, Jezmo you stated that you were running a SuperTigre 51 on gas and it runs very well.
    For me this would be the ideal setup, ie: small, inexpensive, hopefully easy to run. Just wondering what your setup was?
    I was thinking of the following:
    SuperTigre51 or ASP52 running a mix of 5:1 for breakin, and 10:1 after, and not changing the bearings initially.
    the RCexcl ignition found at
    http://www.dlenginesaustralia.com/dl...&productId=125
    Questions:
    Did you just keep the bushes?
    What do you think about the walbro wt-644 carby for this, or was the standard carb OK?
    If you went to pin bearings, what size, and what fuel mix did you go?
    What angle did you set the ignition? (I was thinking about 28BTDC-This ignition has auto retard advance which helps with starting)
    Thanks in advance for any replies
    Rob Fonhof
    Melbourne Australia.
  24. #149
    PlaneKrazee's Avatar
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How well does that 160 fx run on gas? RPM ?
    a never-ending battle for truth, justice and the American way
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
