don't forget echo!
Reply
Old 01-11-2008, 01:42 PM
  #201
rangerfredbob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: don't forget echo!
if you're really going for weight loss, after you cut the end off of the crankshaft, drill a hole in it not deep enough to go through the other side, and leave about an 1/8" wall thickness... can't hurt anything
rangerfredbob is offline
Old 01-11-2008, 06:41 PM
  #202
mikenlapaz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AV8TOR Neat idea. How much of the crank do you figure you off additional if it has already been trimmed to the outside of the seal? I'll keep that in mind when I get back to the Zenoah from parts project. Trading some aluminum for steel is a lightening idea!
mikenlapaz is offline
Old 01-11-2008, 08:51 PM
  #203
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just measure the width of the bearing, and cut the crank so that it has that much, or a touch less sticking out to penetrate the bearing.
AV8TOR
av8tor1977 is offline
Old 01-12-2008, 12:25 PM
  #204
denningpat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Denningpat,heres what the echo "E" looks like.its on the base of the cylinder under the exhaust.It should also be on the back of the case somwhere around the pull start housing.most echos have 2 rings but not all.The one in the pic is a 16 or 18cc but only has one ring but it still has the E even though its old.If yours doesnt have the E i think it might be a shindaiwa or a mc'cullah.It really doesnt matter if your not going to do 3D anywway.It will more than likly fly any high wing airplane with at least 1000 sq inches of wing area in the 72-80 inch size very scale like.Youll get excellent fuel savings from glow and youll be able to use about an 6-8 oz tank.Im planning on putting my echo 17cc or my 23.6cc on my spook.(96)ws.1344 sq in wa.only weighs about 7.5 lbs empty.
Thanks for the info you guys have been real helpful. Has anyone converted one of these? I'll make sure and post outside of the Echo thread next time. Time to start converting.
denningpat is offline
Old 01-12-2008, 03:58 PM
  #205
w5kfg
w5kfg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: av8tor1977
AV8TOR
Where can I get the cdi ignition module for the 23 cc echo conversion
Bill B
w5kfg is offline
Old 01-12-2008, 11:37 PM
  #206
buck1856
buck1856's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rcignitions
chignition
theseare the only 2 ive dealt with but there are others if ya check the classifieds here on rcu.A few hobby stores online sell them.but i would personnally only deal with the 2 ive mentioned in my opion.
buck1856 is offline
Old 01-13-2008, 12:04 AM
  #207
mikenlapaz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I second buck's statement.
Reply
Display Modes
