Cub Cadet
Cub Cadet
Which engine is the Cub Cadet 4 stroke trimmer and is it good for conversion? How would the size and cowlability be compared to something like a Satio 1.80.
RE: Cub Cadet
Hey, the Cub is really a Ryobi, which has been around quite a while and is really a good engine. However it is heavy. The most common displacement is around 26/26 cc. Not a real power house but decent. Must be mounted with the cyl. head up. When converted to EI and a light weight exhaust it will come in under 4 lbs, with a mag nearly 5lbs. best suited to a floater type plane. I just finished a mag version and am pondering if I can make it a glow/gas engine, If I can it should be even lighter than an EI version.
RE: Cub Cadet
Hey TFF, no gas/glow is a mixture of the two, a great concept check out the gas/glow thread for a complete explanation. What type of plane do you have in mind for this engine?
RE: Cub Cadet
I will look into it. I am looking for the right engine for a scratch built Sopwith Camel I want to build. I wish they had more power for a WWII plane.
My Feedback: (27)
CA
RE: Cub Cadet
How much wing area?
How much will the Camel weigh?
What is the recommended engine? This will give us an estamated weight of an engine.
Can you find a thread where some on else has built and flown this aircraft?
RE: Cub Cadet
Yeha!!! GAS/GLOW rocks[sm=wink_smile.gif] we need to hear from a Ryobi 26 on GAS/GLOW; one time I've heard of a Robin 4 stroke on gas/glow but havent heard from it anymore so pleaswe if you try it let us know bhow it worked
RE: Cub Cadet
I am ready to give it a go, my biggest quandry is over the glow plug adpter. The plug is a long reach, and I am some what concerned about the plug being up in a "chamber". I figure it will work, just a matter of how well. The engine is already converted to gas,so the last thing to do is make the adapter. We should know soon.
RE: Cub Cadet
The Camel specifics have not been set yet. The plan is to build it for a competition plane. 1/4 scale but it can go up or down to fit all inside. I am using Replicraft Drawings for the design.
