If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 11 of 24 FirstFirst ... 91011121321 ... LastLast
Results 251 to 275 of 585
  1. #251
    Flight Risk's Avatar
    Join Date
    Jun 2003
    Rocky Flats, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: GAS/GLOW HOW TO....
    ORIGINAL: box car
    http://<font color=&#39;&#39;#00265e&#39;&#39;>http:...008.pdf</font>*this is who has the 90 bend
    Dang it box car, I just lost an hour going throught that site.
    Lots of good ideas and products from the other side of the pond. Check out the fuel tank setup.
    Rod S.
    Just Fly It.
    SIG Brotherhood # 99
    Kadet Brotherhood # 141
  2. #252
    Join Date
    Jun 2005
    Bullard, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've been interested in a RCGF 15cc gasser engine, but the weight is a little much for it's hosepower.
    Would converting this engine to Gas/Glow be viable. Removing the EI would remove 8 oz including the equipment and battery. This would ge the engine down to about the right weight and a little increase in power would be icing on the cake. It looks like possibly the best of both worlds with a simpler operation and cheap fuel.
    I'm looking for a gasser to replace .61 glow that weighs in at 25oz and is close to comparable in power.
    Any comments appreciated.
    CAJUN
    FROM DEEP IN THE HEART OF EAST TEXAS PINEYWOOD
  3. #253
    av8tor1977's Avatar
    Join Date
    May 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, I would say it is definitely worth a try.... I have used Gas/Glow on everything from converted Super Tiger .90 engines up to and including a 50cc Echo twin. Poulans, Homelites, Ryobis, Stihls... Give it a shot and let us know how it works.
    AV8TOR
    If it is not SCARY, it is NO WHERE NEAR powerful enough!!
    All R/C planes have expiration dates---> It's just not printed on them anywhere!
    Just because it's not a good idea doesn't mean it won't be fun!
    Never underestimate my level of immaturity.
  4. #254
    Join Date
    Nov 2003
    tijuanaBaja California, MEXICO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well Bob!!!! I don't see why it shouldn't work if it works on weed eaters imagine how it would work with the timing an power that these chinese engines have, I sell the RCGF line of engines but I havent tried one with gas glow, but I know this for sure even the gassers with CDI benefit in horsepower increase with the Gas/Glow fuel and CDI combo.
  5. #255
    Join Date
    Jun 2005
    Bullard, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anyone, need a good source for the glow plug adapter for CM-6 (10 mm) plug to glow plug. I cannot find it in the Horizon Hobby web site.
    I've seen it somewhere in this sthread, but now can't find it.
    Many Thanks
    CAJUN
  6. #256
    Join Date
    Aug 2008
    Keizer, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i need a few 10mm cm-6 plug adapters that use gasket type not the kind that have tapered seats where they screw onto the cyl. head. i can make some out of some old gasket type spark plugs, but i'd rather ones already made. Cajun1 try C&H ign. Agape engs and ign. on the web.
  7. #257
    Join Date
    Jul 2005
    Salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have some made out of standard 14mm plugs, if I had a junk 10mm plug to modify in my lathe I would make you an adapter...
  8. #258
    av8tor1977's Avatar
    Join Date
    May 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think www.ch-ignitions.com has them.
    AV8TOR
  9. #259
    Join Date
    Aug 2008
    Keizer, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i looked there and i need to call them to see if indeed they are the gasket kind. thanx av8tor1977.
  10. #260
    Join Date
    Aug 2008
    Keizer, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanx rangerfredbob for the offer. how do you make them?????? using a 14mm gasket type spark plug???? and what do you use to fill up the hole with and then tap to 10mm??????
  11. #261
    Moderator w8ye's Avatar
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The problem with the adapters for the perfectionist is that they tend to recess the plug or hide it up in the plug hole for the reach is not as long on the glow plug.
    They will probably talk to you about this at CH?
    Attended the CutFinger Institute of DirtNap University for years but never did graduate....
    Recipient, Mangledhand award August 2008
    Club Saito Member #7
    Original AMA #31261
  12. #262
    Join Date
    Jul 2005
    Salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I get used tapered plugs from work for free (out of chevy 350's generally), cut off the hex part on the lathe which lets the ceramic part fall out easy, I leave some of the flat part behind the hex so I can grab it when I flip it around, next I cut off all but about 3 threads with the lathe and now tap to the 10mm threads (they are just the right size to tap without drilling, then flip it around again and clamp onto the threads with the chuck (it doesn't take much, and I do it with the intent of leaving it in the engine so it works fine) and trim off the other side right up to the taper, this makes the most compact 14mm to 10mm plug adapter you can get. If I'm going for a glow plug adapter I follow the same steps shy of tapping with the addition of making a plug to go in from the combustion chamber side out of aluminum that's a press fit, tapped to 1/4-32, before pressing in I put a dab of green loctite (sleeve retainer).
  13. #263
    Join Date
    Jun 2005
    Bullard, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So far I have not found a 10MM glo plug adapter. Lots of 14MM but no 10MM.
    Any other suggestions.
    CAJUN
  14. #264
    Join Date
    Jul 2005
    Salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    best bet would be to make one or have someone do it for you.
  15. #265
    Join Date
    Jun 2003
    Rocky Flats, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Are you talking 10mm sparkplug or 10mm glowplug? I can't imagine how to get a glow plug to set into a 10mm plug hole, as even 14mm is tight. You could get a glow plug to set flush at the top, but not down inside the plug hole.
    I bought an adapter and other parts from these guys.
    http://www.cncengines.com/rc.html
    Rod S
    Rod S.
    Just Fly It.
  16. #266
    Join Date
    Dec 2001
    Shelby, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't think there would be enough meat in a 10mm X 1/4"-32 adapter for it to be very reliable?
    Original AMA #31261
  17. #267
    Join Date
    Jul 2005
    Salem, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yeah, glow plug is going to be somewhat high on that setup I would imagine.
  18. #268
    Join Date
    Jun 2005
    Bullard, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Apparently these were available commercially at one time, but I suspect they were for 14MM plugs, as they are still available. No one I've found has the 10MM X 1/4-32.
    CAJUN
  19. #269
    Join Date
    Mar 2009
    Guilford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As referred to in post 265, these guys have 14 mm to 10 mm and 14 mm to 1/4-32, but not 10 mm to 1/4-32. For $10.00 each.
    Question: Does amyone make a 10 mm glow plug?
  20. #270
    Join Date
    Jun 2005
    Bullard, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The small RCGF engines use the CM-6 plug which is a 10MM.
    CAJUN
  21. #271
    Join Date
    Aug 2008
    Keizer, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: cajun1
    cajun1 pm me i have some info for you.
  22. #272
    Join Date
    Aug 2008
    Keizer, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: spaceworm
    spaceworm, pm me i have some info for you!
  23. #273
    Join Date
    Sep 2003
    R, VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    av8tor1977 help LOL
    (without reading the whole thread/ Im just going to ask), my friend has an older Super Tiger 23cc or 25cc (not sure what cc),,
    and it has a Glow Type Barrel Carburetor, will the Gas/Glow Mix work with this type Carburetor ????? he/it has never had a problem pulling fuel to the Carburetor..
    thanks !!!!
    Jim
  24. #274
    av8tor1977's Avatar
    Join Date
    May 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Two problems... The carb might work, but be a bit sensitive to adjust. The big problem is that the Gas/Glow fuel mix does not have enough oil for the Super Tiger engines unless they have been modified with a roller rod bearing and a hardened crank pin. If you add more oil, all the percentages of methanol and nitro will be off, and you will be creating a whole new experiment that may or may not work well.
    AV8TOR
  25. #275
    Join Date
    Jan 2006
    riverton., WY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: cajun1
    C&H is closed forever.
    I do have some 10MMX1/4x32 adapters left over have about a dozen of them.$5.00 each plus $3.50 P&H .Just send me a check and number you want plus P&H.
    I do not have gaskets for the 10MM side.You can use a gasket from a 10MM CM-6 spark plug,hard to get off.
    BCCHI
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
