GAS/GLOW HOW TO....
Reply
Old 12-16-2008, 03:20 PM
  #101
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GAS/GLOW HOW TO....
roller bearings
Jim
the Wasp is offline
Old 12-16-2008, 08:10 PM
  #102
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would do the 10% oil in the mix. I have used more than that but it was just a test. If I remember right that is more by a fair amount than AV8TORs mix is for oil...but it should be ok. Just use a oil like Klotz that mixes good in various fuels and does not leave hardlly any carbon in the engine. I never had a plug go bad with that oil also. Capt,n PS I will look up some data I may have on Tartan engines.
captinjohn is offline
Old 12-16-2008, 08:15 PM
  #103
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 12-17-2008, 12:28 AM
  #104
nitro joe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: the Wasp
""ONE part of the glow fuel to TWO parts of the high test, (premium) gasoline.""
av8tor1977
how about running my Super Tartan "Tartan" 44cc glow twin on Gas/Glow,,
I ask because it's such a higher compression engine than the gasoline engines, I believe it's a 11 to 1 ratio, do you think an OS F plug will be hot enough ??
(EDITED) of-course this would have to be mixed with no Nitro as this engine was designed not to run Nitro !!
yes the Super Tartan Twin has Needle Bearing Rod Ends
Jim
Here's the innards,and"Tips"paperwork of a single SuperTartan glow I have in the shop.
Never run.Notice the stout build.
I would not worry too much,about adding alot of extra oil to these guy’s standard gas/glow mix due to it's construction.But that's just me...Your milage may vary.
As for the high compression,you might cut out a couple new head gaskets ~2x the std.thickness.
Mine is just a flat aluminum ring.
ID:	1091269   Click image for larger version
ID:	1091270   Click image for larger version
ID:	1091271   Click image for larger version
nitro joe is offline
Old 12-17-2008, 12:49 AM
  #105
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like directions says mix 8 oz oil into 128 of mentanol. Would that be 16-1 ratio? Capt,n
Old 12-17-2008, 02:28 AM
  #106
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my manual for my Twin Glow says 10% oil,
and my manual for my Single Glow says 10% oil also,
but I have specs for the Gasser Single and it says 5% oil,
Jim
the Wasp is offline
Old 12-17-2008, 02:39 AM
  #107
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
EDITED
quote ""never prop engine to turn less than 8400,, 18x10 good size prop to start with "
OK,, so I have to go down from an 18x10 to get to 8400
Jim
the Wasp is offline
Old 12-17-2008, 09:38 AM
  #108
nitro joe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: the Wasp
EDITED
Jim
Edit: I'm now wondering if that "Tip" sheet included with the engine is the correct one for the Tartan single?
18x10 at 8400 seems a bit optimistic to me.
Anybody know?
From post #104
"Here's the innards,and"Tips"paperwork of a single SuperTartan glow I have in the shop."
Please take note,that the included "Tips" sheet,listing the prop size is for the "single" not the twin.
Old 12-17-2008, 07:20 PM
  #109
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
""listing the prop size is for the "single" not the twin""
yes, I understood that, I have both the single and twin..
what does everyone use for a prop on their OS 120 4st,,
Jim Cline has flown the Tartans more than anyone inside the US, he told me (on the phone) that the Super Tartan single is a little more powerful than a "good" OS 120, it would be more like a 130..
I don't know why they want it turned that high, it doesn't have that much for an Exhaust Timing, I don't think the single will even turn a 17x10 that high, the Saito 125 turns an APC 16/6 at 8000..
Jim
the Wasp is offline
Old 12-17-2008, 08:53 PM
  #110
nitro joe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The “tips” sheet pictured in post 104,and shipped with my 22cc single years ago, must be for the 44cc twin .
18x10 is Zenoah G-38 territory. From that mfg. specs: ”Benchmark prop 18x10 APC 7,300”
Wasp,I understand that you have both engines w/ manuals,and know this stuff. Someone else may also have the single w/o manual,trying to spin too much prop like I would have after reading the paperwork received.
Old 12-17-2008, 09:37 PM
  #111
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: the Wasp
Jim
How much more does the Tartan single weigh over a good OS1.20? That is the question! Capt,n
Old 12-17-2008, 09:45 PM
  #112
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK,,
I know the Twin (s) are screaming little monsters, guys report 8400 with a 20x8 and around 8000 with a 20x10,.. my MVVS 35 turns a 3W 20x8 at 7200 tuned for flight and top speed is pretty good in my plane, and my Twin is lighter than my MVVS is with Mount/Muff/Batt/Igni,, my plane would really zing with the Twin, ,my plane weighs 15 &1/2 with my MVVS,,
av8tor1977 .. I didn't see what fuel line you said you were using,, that's a question in sort LOL
Jim
the Wasp is offline
Old 12-17-2008, 09:48 PM
  #113
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
""How much more does the Tartan single weigh over a good OS1.20? That is the question! Capt,n""
now you would have to go ask that one LOL
I don't know LOL
Jim
the Wasp is offline
Old 12-18-2008, 10:05 AM
  #114
nitro joe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
“How much more does the Tartan single weigh over a good OS1.20?”
The Super Tartan single as shipped w/ muffler,and prop adapter,
comes out to 44oz.(2.75lb.) on a cheapy kitchen spring scale.
You'll have to check on the OS weight.
Old 12-18-2008, 11:43 AM
  #115
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More data on the Tartan engines http://www.rcuniverse.com/forum/m_4600212/tm.htm Capt,n
Old 12-18-2008, 05:01 PM
  #116
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the heaviest OS 120 weighs 32.5 oz..
http://www.osengines.com./engines/surpass.html
Jim
the Wasp is offline
Old 12-19-2008, 06:35 PM
  #117
JohnF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Despite all the great information here for doing the conversion I think one thing has been overlooked and that is what stopper should be used on the fuel tank. I have used Sullivan, Du-Bro and Kavan tanks with the gas/glow mix but the only stopper that didn't desolve was white in color. The black and or brown (gas) stoppers did not last. So, I am hoping some of you guy's can add to this and also what fuel fillers are you using? Dubro makes nice "Kwik-Fill" ones for Glow or Gas but can either be used for the gas/glow mix?
JohnF is offline
Old 12-19-2008, 07:40 PM
  #118
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had no problems with the "For gasoline" stoppers, but I don't leave fuel in the tank after flying.
I lost my only regular gasoline/ignition powered model, a beautiful Christen Eagle biplane to the fact that a supposedly "For Gasoline" stopper dissolved and the bits made the engine quit at a most inappropriate time... []
I had tested the stopper by soaking in gas overnight and it was fine. But I forgot to de-fuel the plane after flying one time, and when I flew it a week later is when the problem occurred and it died an early death. Post mortem revealed a disintegrating fuel stopper that caused carb blockage and the engine to quit right as I was adding power to make it over a concrete wall on final approach. What a horrible "smack!" that made. I just wanted to sit down and cry...
AV8TOR
av8tor1977 is offline
Old 12-19-2008, 10:53 PM
  #119
aero nut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well sullivan products came out with a stopper that works on both Glow and gasoline fuel so it should work very well for our application
Saludos Converts
aero nut is offline
Old 12-20-2008, 01:12 AM
  #120
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
aero nut ,, I have heard of that Stoper,,
now,, what fuel line ?????????!!
Jim
the Wasp is offline
Old 12-20-2008, 08:01 AM
  #121
JohnF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Tygon fuel line seems to work fine with gas/glow.
JohnF is offline
Old 12-20-2008, 12:24 PM
  #122
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep. That is what I use on the airplanes. On my flight box, I just have some cheap plastic (vinyl?) tubing from the hardware store. It has gotten a little bit stiff, but has held up without problems for about 2 1/2 years using Gas/Glow fuel.
Here is a good source for tubing at a great price: http://www.rotaxparts.net/scripts/pr...?idCategory=55
Either the "Tygothane" or the blue urethane primer line works very well. The primer line is not pliable enough to use inside the fuel tank for a clunk tube however.
AV8TOR
Old 12-20-2008, 03:03 PM
  #123
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK thanks
Jim
the Wasp is offline
Old 12-20-2008, 07:13 PM
  #124
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Last time my wife was at Hospital for a test...they gave us a bunch of clear tubing in 2 sizes. I think I will try some and see what happens. Capt,n
Old 12-20-2008, 07:40 PM
  #125
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man,,,,,,,,,,, all this talk makes me want to get to the field and fly,, but it's cold out therrr and we got a good foot of snow eeerrrr, after all these years I have learned to hate the cold and snow !!
Jim
the Wasp is offline
Reply
Display Modes
