Poulan chain saw engine...HELP!
Reply
Old 06-03-2003, 04:22 PM
ZmOz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Poulan chain saw engine...HELP!
I'm thinking about buying an 18" Poulan chain saw with a 40cc engine to make something out of. The only thing I'm confused about is the crankshaft...how exactly do I attach a clutch or something to it?
ZmOz is offline
Old 06-03-2003, 05:51 PM
bn120
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what are you going to use the engine in.
Darin
bn120 is offline
Old 06-03-2003, 06:15 PM
ZmOz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Darin
Not exactly sure yet...but some sort of car/truck.
ZmOz is offline
Old 06-03-2003, 06:42 PM
Volfy
Volfy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I talked to a guy here locally that builds 1/4 or 1/5 scale monster trucks with Poulan chainsaw engines. He said he used the stock clutch assembly that came with the chainsaw. I never actually saw the trucks he made, but he was going to bring them into the LHS for show some weeks ago.
The idea sounds pretty workable, since the chainsaw clutch already has a gear on it, which can be used to gear down the drive shaft speed. I suppose you could also use the centrifugal type clutch in weedwackers if you want an "automatic" clutch, though I would recommend a failsafe engine cut mechanism in case the car/ boat get into a runaway situation with the throttle somehow stuck wide open. Judging by how much at hit by my E-Maxx can hurt, a 40lbs car can do some serious damage.
Volfy is offline
Old 06-05-2003, 04:35 AM
ZmOz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So nobody knows what the crankshaft looks like? Using the stock clutch might be an option...but I would still like to know what size/shape crank it has...
ZmOz is offline
Old 06-05-2003, 05:49 AM
Antique
Antique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The crank has a taper shaft on one end with a flywheel on it for the spark, and a straight shaft on the other end with a centrifugal clutch on it for the chain....they're all the same....
the taper end has an 8mm right hand thread on it, the straight end has a left hand thread for the clutch....
Antique is offline
Old 06-05-2003, 09:19 PM
ZmOz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What size are the threads for the clutch side?
ZmOz is offline
Old 06-05-2003, 10:29 PM
Antique
Antique's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Poulans I have are 46cc, the thread is 8mm by 1 pitch...
Antique is offline
Reply
Display Modes
