ECHO SB1080 runs great!
Old 02-20-2010, 05:33 PM
Scota4570
Default ECHO SB1080 runs great!
Thanks to all who helped with their great suggestions.
This is one is a 50cc Echo short block. The carb is a WT542. The ignition is CH. The prop is a 20x10. I made everything else. The muffler is the base of a little gas cylinder, a piece of flat stock and part of a lawn chair. The hub is bar stock aluminum. The prop shaft is part of an old waterwell draw bar.
Results? idle 1550 rpm...........high end? 8100 rpm. I am elated! It runs smooth too.
Time to re-engine the old Big Bee. This one is a lot better than the 65 cc that is in it now! This one calculates to 5.6 HP, and 28-pounds of thrust.
Perspective, 5.6 hp is double my old mini bike horse power, impressive.
Scot
ID:	1383212   Click image for larger version
ID:	1383213   Click image for larger version
ID:	1383214   Click image for larger version
Old 02-20-2010, 05:50 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: ECHO SB1080 runs great!
You did good
Old 02-20-2010, 07:08 PM
Scota4570
Take it back! Just loked a the prop, it is a 20x8. Still very happy though.
Old 02-20-2010, 10:19 PM
av8tor1977
av8tor1977's Avatar
What brand prop?
Nice job!
AV8TOR
Old 02-20-2010, 10:39 PM
Scota4570
ORIGINAL: av8tor1977
What brand prop?
Nice job!
AV8TOR
Master Airscrew 20x8 Classic G/F Nylon Propeller
BTW That giant muffler can will get trimmed down. Big volumes seem to keep it quieter and that is good since my neighbor gives me trouble from time to time and I don't want to give him any ammo. As an aside, I started making a simmilar muffler from the bottom of a disposable fire extenguisher. I did not think ahead and it got destroyed on the lathe. Even so the thickness of material and overall size is about right and the price is perfect. I'll have to check with a fire extenguisher outfit and see if they will make some donations.
Old 02-21-2010, 01:15 AM
av8tor1977
av8tor1977's Avatar
Pretty neat huh? You have a high quality, 600 dollar engine for a fraction of the price, and the self satisfaction of doing it yourself. That's what it's all about! Congrats!
AV8TOR
Old 03-05-2010, 01:55 PM
Falcons Cuz
HELLO Scota4570
I AM ALSO PLANNING TO CONVERT ONE OF THESE ENGINES INTO AN RC AIRPLANE AND I AM FINDING SOME PLANS ABOUT THE CONVERSION SO IF YOU PLEASE GIVE ME SOME MORE PICS AND CONVERSION INFORMATION ABOUT THIS ENGINE AND ALSO TELL ME THAT FROM WHICH EQUIPMENT DO YOU EXTRACT IT THEN I AM REALLT THANKFULL TO YOU
AND PLEASE ALSO GIVE ME THE DIMENSIONS OF ENGINE SUCH AS PISTON DIAMETER AND THE PISTON STROKE
WAITING FOR YOUR REPLY
Falcon Cuz
Old 03-05-2010, 09:52 PM
Scota4570
It was not extracted from anything. It is a short block bought as such, Echo part number CS1080. There are a couple of places that have it as a replacement part. I made the hub myself, see the attached photos. the mount is made from angle stock then JB weld, glued and fastened with machine screws. The muffler is the bottom of a gas cylinder, a little fire extenguisher work too. The exhaust pipe is the shaft of a weed wacker. Ignition is RCEXL.
ID:	1391811   Click image for larger version
Old 08-03-2011, 03:54 PM
MSS999
Hi,
Do you have the AUW for that setup?
Also, did you do any port work etc. to improve performance or is that a straight SB1080?
Thanks.
MSS.
Old 08-03-2011, 04:39 PM
w8ye
My Feedback: (16)
w8ye's Avatar
It amounts to being the same engine as a purchased BME 50. http://www.bmeengine.com/engines.htm
Old 08-03-2011, 08:46 PM
Scota4570
Like he said. It is a straight up short block. I did not do any internal mods. I see no reason to do so. It runs very reliably and strong. I have never even cracked the case. Randy's small engine repair on EBAY can fix you up on the cheap for a new short block. I fabricated the prop hub, intake manifold, and muffler. I just enjoy that kind of work. I did not eliminate the rear oil seal. I might do so if I take it out of the airplane. You can buy the bits and pieces already done. It is a very simple assembly job if you buy the pieces.
Old 10-27-2012, 05:25 PM
rcflyerds
Scota4570 -
So 14 months later I find this thread and hope you are still out there and maybe have an answer to a question about the Echo SB1080 short block conversion. I'm interested in doing one of these and have no problem with acquiring most any of the "parts" to do it (I actually already have the short block and a Walbro 542 carb). My problem will be with the prop hub as I don't have the tool resources to make one myself. You mentioned that "you can buy the bits and pieces already done" in your previous post. Does this mean that you know of a place to get such a prop hub? That would be the only thing holding me back from leaping into this conversion. I imagine I could find a muffler somewhere as well but if you also know who's would fit that info would be much appreciated as well. It's tinkering time here in Montana now so if you have any idea about sources for these items-especially the prop hub-that would be great.
Dennis
Old 10-28-2012, 07:44 AM
Scota4570
There was an outfit that had prop hubs, mufflers and mounts for echo, poulan and a bunch of others. My wife has trashed my computers. My old favorite lists are all gone. I searched for a while and can't find the company. It may be RC extreme power but, if so they don't carry that stuff any more. Maybe somebody else know who I am describing? Good luck.
Call these guys. http://indianatinygasengines.com/page1.aspx
Old 10-28-2012, 07:51 AM
MSS999
I believe you may be thinking of Brillelli Custom. They don't seem to be around any more.
Old 10-28-2012, 10:42 AM
Scota4570
Bingo!
Old 10-28-2012, 05:14 PM
rcflyerds
I remember Brilleli being out there too - at one point I was seriously considering their 45. I'll give Indiana Tiny Engines a look-see. Thanks for the tip!
Old 10-28-2012, 07:36 PM
tkg
Try BME
Old 10-29-2012, 09:40 AM
rcflyerds
tkg,
Good tip, shoulda thought of that myself. BME has the prop hub for $89.95 plus shipping so problem solved. Thanks everyone...
