Spark advance question
Old 03-25-2010, 09:38 PM
Scota4570
Default Spark advance question
I have an idea for a mechanical advance I would like to try to make.
I am not understanding which way the advance goes. One times an electronic ignition at about 30 BTDC static.
So now I run the engine. I flip the prop and it fires at 30 btdc? It then advances to TDC as I rev up the engine?
Or, does the 30 represent the the most advance and it fires at about zero when the engine first starts and the ignition module senses the motion? Then I rev it up and it moves the timing to 30 BTDC?
Old 03-25-2010, 09:49 PM
Lnewqban
Lnewqban's Avatar
Default RE: Spark advance question
Any mechanical spark advancing mechanism allows the spark to occur sooner (relative to crankshaft degrees) as RPM increase.
Check this article out:
http://en.wikipedia.org/wiki/Ignition_timing
Old 03-25-2010, 10:31 PM
Aussie Maddog
My Feedback: (16)
Aussie Maddog's Avatar
Yes 30 BTDC is the most. Start at 6-8 BTDC.
Old 03-25-2010, 10:37 PM
Scota4570
ORIGINAL: Aussie Maddog
Ok, that is what I meant. I would want it to fire at 6-8 BTDC at idle and advance to 30 at full rpm.
Old 03-25-2010, 10:38 PM
Aussie Maddog
My Feedback: (16)
correct. Generally full advance is at around 4000 RPM.
Old 03-26-2010, 05:24 AM
azalner
My Feedback: (8)
This is a mechanical advance I did about 20 years ago. It is an Al Diem conversion. Just for information, you might glean an idea or two.
AlZ
Old 03-26-2010, 10:13 AM
tkg
Perfect timing for most engines. 6 deg BTDC at idle and 30 degrees BTDC at full throttle. IN reality 4-8 at idle and 28-30 at WOT. If you have to chose which end of throttle to have the timing correct at chose WOT and live with what ever idle is.
Old 03-27-2010, 02:45 PM
Scota4570
Nice work on the OS. My thought is a new "flywheel" of absolute minimal mass. Use neodium magnents to induce the spark. The advance would be centrifugal. If I can make it come together as i visualize it is would be lighter than a CDI and retain the advance feature. Since many smaller engines need a starter anyway there would be no trade off.
Old 03-27-2010, 03:32 PM
gr8flyer55
TKG, is there a way to repair a synchro spark that is giving double sparks and misfiring? I think it got smacked in a mishap at our field, and was given to me by a friend.
John
