Little Zenoah grey coil??
1 Attachment(s)
Does anyone have one of the little Zenoah grey ignition coils they would like to get rid of super cheap? I need one.
Thanks, AV8TOR |
RE: Little Zenoah grey coil??
One can buy small ign coils on Ebay...look in "pocket bike"
Some are about $8 to $10 |
I have dozens of Zenoah grey coils but the are all different from the one in your picture. Mine have a red, black, and the Sparkplug lead. Mine are made for CDI ignitions. Maybe I have another type also, I'll look. If I do, the mounting lugs are at either ends of the coil, while yours are in the middle. ??
John |
ORIGINAL: gr8flyer55 I have dozens of Zenoah grey coils but the are all different from the one in your picture. Mine have a red, black, and the Sparkplug lead. Mine are made for CDI ignitions. Maybe I have another type also, I'll look. If I do, the mounting lugs are at either ends of the coil, while yours are in the middle. ?? John Thanks, AV8TOR |
1 Attachment(s)
Here is a pic of one of the many coils that I have. It is made to be used with a CDI. If this is what you are looking to replace, it will work great. Very low primary resistance, again intended for a CDI unit. Plug wire will thread into the socket so you can use any type you require.
John |
I just sent you a PM. Send me them with the plug wire if possible.
Thanks!! AV8TOR |
