RE: Convert GMS 120 glow to Gas
I tried the pressed sleeve on the crankpin on one of my 2300 and it eventually worked lose after a few runs so I had to replace the pin with a hard ground dowl pressed into the crank and have no problems sense .
by the way I am in clearwater Fl. now for a few months if you want to see one of my engines.
Florida??? Does this mean you've officially retired of being a Texan:D
we will be here for 3-6 months , we still have a texas residence and adress . Did you get that engine converted yet?
I'm on the east coast Palm beach area. So clearwater is far for me otherwise definitely I would have met you.
Now I wonder why the press fit sleeve would come out? Do you know the reason? I had to apply a lot of force to fit it in.. Borna |
1 Attachment(s)
I got this far then moved on to another project, I'll get back to it one of these days.
I think it is because the piston and rod kinda starts beating on it ans eventually gets lose and starts turning, my opinion but it did it on 2 engines and both were press fit.
I pressed on a commercial inner race on a pair of ST-3000's and never had a problem.... you need a TIGHT press though....
1 Attachment(s)
flipflop: Are you still running the Mack MB260 engine yet. Mine is taking a heck of a beating in my leaf blower this fall. She screams!!!! Capt,n
Ok guy,
I'm planning to test the engine sometime this week. My question is, usually in this kind of conversion what should be the initial ignition timing? 10 , 20, 25, or 30 degree before TDC and why? Thanks Borna |
ORIGINAL: borna Ok guy, I'm planning to test the engine sometime this week. My question is, usually in this kind of conversion what should be the initial ignition timing? 10 , 20, 25, or 30 degree before TDC and why? Thanks Borna |
Generaly speaking there is little or no gain after 20 degrees of advance for smaller engines
and they start easier at 20 than 28 degrees. |
Thanks guys.
So what are the disadvantages of less than 20 degree. Let say 10 degree BTDC? Also since this will be my first gas engine, what should be the starting procedure as far as how much gas I need in the carb before starting it? The carb I'm using has a pump but no chuck or primer bulb, so I have to prime it with my finger on the hole. When priming it do I need the throttle opened or should be closed? Thanks Borna |
ORIGINAL: Ralphbf Generaly speaking there is little or no gain after 20 degrees of advance for smaller engines and they start easier at 20 than 28 degrees. |
The universal magic timing number for 95% of our engines is 28-30 D BTDC.
The oddballs are the YS engines and some of the older big tigers on gas. The YS likes 25-26 and the ST's 26-28 |
When the piston is at TDC there is a few degree of free play on connecting rod and crankshaft before piston starts to move down. Are you consider that free play as part of TDC or not.
For example, when piston is all the way up, it will take for example 2 or 3 degree of conterclock wise before piston starts to move down. so TDC consider + the extra 3 degree of the free play or - the extra 3 degree? Thanks Borna |
1 Attachment(s)
There is only ONE good method for finding top dead center, and all degree measurments when working with engines are measured from that. It is called the "positive stop method", and it deals with the dwell period at TDC that you speak of, and it is used in everything from race engines worth many thousands of dollars, all the way down to our little engines.
You insert something into the spark plug hole that will not move in the slightest, but will stop the piston just before it reaches top dead center. You then install a degree wheel, and "eyeball" top dead center on the wheel/pointer. Then turn the engine over gently until it stops, and note the degree setting. Then turn the engine over gently in the other direction until it stops and note the degree setting. What you are looking for is a degree wheel position that affords the exact same number when the engine stops in either direction. Adjust the degee wheel until you have this condition. When you achieve this, the degree wheel will be indicating an actual top dead center when the degree wheel reads 0 degrees, TDC, (once you take your "positive stop" out). All measurements, whether they are for port timing, cam timing, ignition timing, whatever, are referenced from this point. Here's a pic of the "postiive stop" that I made for my engines. It uses a hollow tube in the center so that you don't have to fight compression when turning the engine over. AV8TOR |
Yeah I know Terry, you just "fake it" and it's probably close enough that one couldn't measure the difference, but then you have been doing this for a while.... ;)
AV8TOR |
We have done this a little different.
Turn the crank one way until the piston just stops moving up the cylinder and mark the crank. Turn the crank the other way until the piston just stops moving up the cylinder and mark the crank. Measure the distance between the two lines, divide by two and mark the crank. You now have top dead center. You can put most anything in the spark plug hole and watch it rise so you can mark the crank. This works very well and takes no special tools . |
That'll work too. Same idea, slightly different method. I made the tool with an old spark plug and a piece of aluminum tubing JB Welded into it. It's handy and works faster for me, especially if I happen to be working on an assembled V/8!! ;)
AV8TOR |
A dial indicator is real precise....and not that costly. Handy for many engine projects. Capt,n;)
A dial indicator will not find TDC unless used along with the manner posted by Ralphbf. By itself, a dial indicator will not allow for the dwell time of several degrees of crank rotation at TDC.
AV8TOR |
It will work...just depends. On some engines with a flywheel you can have degrees marked on the flywheel. But you can use a dial indicator to make sure "O" Top dead center is marked right. The point I was making ...instead of using a spark plug "stopper" you can use a dial indicator in it place. Of coarse you would use the other gizmo's if you like.! Ha! If you want to try something interesting, use a timing light while engine is running. Some of the stock mag systems do have advance built in...like on my MB290. You can freeze the prop and read the size on it!!! Capt,n
After I put the degree wheel on and find TDC I mark that and 28 degs. on the drive washer so I can set it with a timing light later and not have to use the degree wheel again. It is just sooo much easier to clip the timing light on and check the marks.
Sorry to disagree Captain, but I don't want others to be mislead. A dial indicator will not show true top dead center. It will show when the piston reaches it's highest point, but that is not true top dead center by a number of degrees. How much depends on rod/stroke ratio, etc. but the point is, it is not true top dead center.
After the piston reaches it's highest point, the crankshaft will rotate several degrees before the piston starts back down. That's called it's dwell time, and that's why you can't simply use a dial indicator to find TDC. AV8TOR |
