Body spinning on Big Lama
My Feedback: (10)
Just purchased a used E-Sky Big Lama which is a brushless conversion from RC711. Transmitter E Sky ET4 dip swithes (Ail up) (ele up) (thr down) (rud down). On spool up heli lifts, fuse rotates as soon as enough throttle is given for lift. At very low throttle have left and right rudder control, slightly more throttle and body spins. any idea's on what to look for would be appreciated.
George
George
RE: Body spinning on Big Lama
Does the heli spin like crazy just after leaving the ground? If gain trim on 3 in 1 is set properly it could be a gyro compensation reversal due to wrong connections on 3 in 1 unit. Try this. Change the positions of the two motor drive connectors on the 3 in 1 unit (the red connectors) , change position of RUD switch on your transmitter and try again.
My Feedback: (10)
Appreciate the responce . . . reversed the motor leads on 3 in one and now gyro hods like it should.Part of the fun of buying used with no schematics . .
