big lama antenna loss
hi, Ihave lost the rx antenna wire on my 2.4 big lama. any way to replace? how bad will it affect flight? also, one motor does not work,red light comes on 3in1 at about half throttle. any help greatly appreciated. thanks
RE: big lama antenna loss
ORIGINAL: chubster
The antenna wire is 32mm long - and if you have a soldering iron it is replaceable with antenna wire available from your Local Hobby Shop.
If not, you don't really need it - but it will lower the range that your bird will pick up a radio signal from your Transmitter to around 30 metres (about 90 feet) Line Of Sight - so if you are not planning to try out the limits of flight, it should be OK as is[sm=wink_smile.gif].
The motor prob is a difficult one to diagnose from afar, but it is either the actual motor (to test this unplug the other motor - marking the way it is plugged into the 3in1) and plug "dead" motor into those pins...............) or more likely a dodgy/fried 3in1. Sorry. The easiest thing you can do is to order [link=http://cgi.ebay.com/ESky-001337-EK2-0709-3in1-3-1-Controller-Big-Lama-S-/130475241548?pt=Radio_Control_Parts_Accessories&hash=item1e60ee304c#ht_1129wt_694]a replacement 3in1 from HongKong[/link] if this is the case[]
Peter[sm=shades_smile.gif]
P.S. You may be able of get a 3in1 closer to your location - but [link=http://www.xheli.com/eskybiglama.html]Xheli.com[/link] is Out-Of-Stock of most parts for these
