Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
3 in 1 controller esky cp3 problem
Reply
Old 10-18-2012, 07:32 AM
pshiv
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 3 in 1 controller esky cp3 problem
Hi. I've a problem with the esky cp3 2.4GHz 3 in 1 controller. The led on the side of it just blinks red and green after plugging in the battery, throttle stick and trim all the way down. It doesn't change to solid green. I've tried rebinding it multiple times, but that doesn't work, all the servo's work when I move the sticks. But when Imove the throttle on the control it changes to solid red. The heli is brand new too. I've tried searching the internet and multiple forums for a solution to my problem, but I've come up with nothing. Please help.
Parker
pshiv is offline
Old 10-26-2012, 08:33 PM
pshiv
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 3 in 1 controller esky cp3 problem
Additional Question:
After playing around with my helicopter a little bit Inoticed that when I put the throttle all the way up the green light on the 3 in 1 controller stays green like its supposed to. If I reverse the throttle switch on the remote, when the throttle stick is all the way down it turns and stays green. Has anyone else seen this before? I'm a little nervous to plug in the main motor to see what will happen if I start with the throttle all the way up. Also, do the two switches underneath the batteries might have anything to do with my problems? There's nothing in the manual about them.
Thanks in advance,
Parker
pshiv is offline
Old 11-05-2013, 02:02 PM
thornuk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My CP3 is a later model with a 4in1 receiver, so it may be different, but in the manual it does refer to the switch positions under the battery, as relating to different models, so it might be worth checking that again. I'm assuming you switch on the remote tx before connecting the heli battery (unpredictable things happen if it's done the other way round). My manual isn't to hand at the moment - I'll check it out if this doesn't fix it (or you haven't solved it another way). Best.
thornuk is offline
Contact Us Archive Advertising Cookie Policy
