Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
bad vibration
Reply
Old 06-14-2007, 10:15 AM
minitman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default bad vibration
My honey bee fp seems to wobble around on the floor then go into the air and wobble tip over into the ground...how do i fix this?
minitman is offline
Old 06-14-2007, 11:27 PM
mrasmm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: bad vibration
you might just need to give it some more throttle and get it up in the air. If it still wobbles real bad in the air you're gona need to balance it and check to see that the main shaft is straight.
mrasmm is offline
Old 06-14-2007, 11:38 PM
DriveWRX
DriveWRX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another thing you might want to check that each blade is the same tightness to the rotor head. I notice My HBFP will have a bad wobble when the "tightness" is not matched. I like to run my blades on the tight side, others like loose. Either case make sure it's equal.
DriveWRX is offline
Old 06-15-2007, 12:16 AM
Whirley Bird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like DriveWRX
says keep the blades a bit on the snug side but a wobble while it's in flight tells me something is way DriveWRX
out of wac.
Make sure the pitch on both blades are the same.
The padless should be just as level as you can get them.
Check the distance fron the head to the metal grip on the paddles.
They should be exact as you can get them.
When you have a wobble while in flight you can be sure it's one of the parts that spin fast
Vegas/ http://www.dream-models.com/eco/flying-index.html
Whirley Bird is offline
