Honeybee King v2 tuner shop
#4751
WI
RE: Honeybee King v2 tuner shop
53 Willys
I have to assume you want pics of the tail mod. Well first let me say sorry about the quality. I've spent more on my helis than I ever would on a camera. My new phone cam probably took better pics but I can't get to load here. So anyway here you go, again sorry for the pood quality.
#4753
CA
ORIGINAL: crashcrash
Hey "Z"...here's a msg from Charles. He's the one you sent to me to fix his heli. He bought the Ranger fuselage for me and I sent him a picture of the completed project....
Vic,
Very nice.... Your a perfectionists and do impeccable work.
I have been flying my helicopter and getting better all the time..... What a difference when things are put together right. Thank you!
Charles Ferrell
Vic,
Charles Ferrell
Peace Crash,
You have our(Chuck and I) vote...
Z
#4754
WI
Well no, what I did (again sorry for the pic quality) was not use both haves of the link set with a threaded rod in between. I used only one link per blade cut down to allow full pitch slide movement, mounting it using the stock link screw from the pitch slider to attach them. I used a pair of side cutter to cut mine, then sanded the cut edge smooth, screwed it on, viola!
#4755
CA
ORIGINAL: skippy7399
53 Willys
53 Willys
Z
#4756
MI
ORIGINAL: Zimatosa
Other than the fact that you offered to fix peoples heli's for them, and do it correctly, I have learned so much from using all your tips that it was an easy name to drop. He does not live too far from where I am so I am hoping that he "flies" into town(he is a pilot) with his King so we can rip a few batteries off together. I might even be able to fly some of that handy-work.
Peace Crash,
Z
Vic,
Charles Ferrell
Vic,
Charles Ferrell
Peace Crash,
Z
#4757
OK
I used to just use a longer screw through the pitch slider to create greater distance between the link end and the pitch slider, I would use a slightly larger diameter coarse thread self tapper to hold well in the pitch slider and then adjust from the back side. Then I went to a cnc tail upgrade (NOT ESKY) and never had to worry about that problem again, lol.
#4758
Well call me an idiot! I just got my new Dynam ESC and i dont know how to install it. I have three red wires? Which one goes to which color. and pics would be extremely helpful! I bought a programmer as well hope it works!
#4759
MI
Depends on the motor colors. Mine are red, black and blue on Esky 3800. Blue goes in middle and I think the black was on the positive side on mine, but i cant remember right off hand as its not in front of me. I did trial and error and had it backwards at first (gear spun the wrong way).
#4760
ON, CANADA
ORIGINAL: bosborne0010
George
#4762
PA
Hi Rusty,
What brand of cnc tail upgrade are you using. I would like to upgrade my K2 but want to stay away from the esky stuff.
Jim
Jim
#4763
My Feedback: (20)
Reel109 I use esky cnc tail box and rotor head and it works fine ,still works great after some bad crashes, but im sure theres better stuff out there.
#4764
MI
ORIGINAL: Fly To Chill
#4765
OK
Hey Jim, I use only the hdx or microheli, no offense chill but the esky stuff is crap. I have used MH or hdx for over a year now and every single time I install one or send one out to a customer for them to run I get the same response of how incredible the difference is. The upgrade collar is 8mm and the boom on a king is 7.5 so you will have to run a spacer, I use an aluminum collar insert that I custom make for each of my applications that I include if a customer wants, or you can use heat shrink which works pretty well. For those of you still looking to extend your boom, the upgrade is a perfect fit for an art tech falcon boom which with minor dremel work fits a king very well, it will give you an extra 1/2 inch extension and increase the tail hold (or dumb it down) pretty well. The MH or hdx upgrade has multiple benefits performance wise where as the esky stuff is at best stock replacement parts in metal, I have tried other cnc upgrades and as Crash stated you can really get some junk out there. The MH or the hdx runs $55 so its not like it is way more expensive than its lesser counterparts and there is no comparison in the toughness and performance, best I have found on the market.
#4766
PA
Hi Rusty,
If I decide to go with the microheli stuff, what parts would you suggest. I was on the microheli web site looking for the components to upgrade the tail and it got a little confusing.[]
Jim
Jim
#4767
MI
ORIGINAL: betapilot
#4768
PA
Yea, I know what you mean Crash, but the last time I replaced the tail box with plastic parts, it just did not fit correctly and I still think it is not working as freely as it should.
Jim
Jim
#4769
OK
Hey Jim, The set I sell comes complete, no assembly required except for removing one side plate in order to install it. I would not piecemeal it together but use the entire assy that way you still do not have any weak links left over from the stock tail assy. It takes about 15 minutes to install and is very straight forward and you will notice before you ever get it on how much difference there is between it and stock. I have plenty in stock since it is a very popular upgrade if you decide you want to try one out.
#4770
Hey guys I have another quick question.....
I have been running the xtreme plastic blades for most of my learning in the last few weeks...I had gotten really good at hovering in one spot with out moving or working the sticks very much at all...well I had a dumb mistake happen last night(read about it in the cnc king head thread) that took out/bent my blades so bad they are unusable.
I had some ebay blades..the 5 pair deal..and put them on today for the first time...man they are VERY VERY touchy!!! I cant seem to keep it in one spot for the life of me!!!
I know these ebay blades are like half the weight of the plastic blades...and I know I read lots of guys say the plastic blades are lazy/slow..but this is a BIG difference between the two!!!
maybe I set my bird back up wrong?? but I dont think I did, everything seems to be just fine from what I can tell...level swash, level everything!!
would blades make this much difference in the way the bird flies??????
Mark
Mark
#4771
MI
ORIGINAL: 53 willys
Mark
Mark
#4772
PA
Hi,
I also used the xtreme plastic blades and switched to the stock wooden ones. I also noticed how much more sensitive they were. I don't know if the airfoil is different but the plastic blades are heavier.
Jim
Jim
#4773
OK
Hey dude, Check the width of the ebay and the extreme blades, I bet the ebay blades are thinner and thin blades are really touchy.
#4774
Hey everyone, my plastic tail gearbox is bent because i fasten it too tight i think. so i bought the new one, but i found it much worst than the one was on the boom. Rubbish molded plastic doesnt even fit on the boom properly. I think i should get the cnc one.
Which one do you suggest? The esky one or somthing like trex450?
Another thing, im thinking about a new batt upgrade. Is the belt cp stock battery(1800mah 20c) is good for the king or not? Or you suggest another brand with another power?
your kind info would be appreciated.
#4775
OK
On the cnc tail upgrade, refer to the previous posts on this page.
On the battery, I am going to put my 2 cents in for the outrage batteries, I fly the 1300 and the 1800 25c's in the kings and they do very well. I would not run them if you are on the stock motor and esc though. They come with a crash replacement guarantee which is obviously nice and they are very reasonably priced - 1300 $32 and the 1800 $45, the 1800 esky which is only 20c runs $40, lol.
