........."BELT-CP THREAD"........
Yes thatscorrect. Using my DuraTrax temp gun. Although that's hot I guess were in the clear............at least for now. I dont know how well she'll hold up running pack after pack. I suppose it'll be a good idea to let her sit for like 10minutes between flights. If anything changes I'll let you guys know.
Joey, from what I have read electric back to back flying is not recommended. Although over the long British winter I have been guilty of doing this just to warm my hands on the next battery pack
Just to reiterate and concur with Bill; head speed too low... ESC gets very hot. I know for for sure Bill will take that from me hands down. Head speed up. I get about 41 degrees celcius. I used to live the the low head speed area.
Cheers
You think taking the wrapping off would help much?
I took the wrapping off my stock ESC. The fact that it then fell apart took me be surprise (i.e. wrapping holds the heatsink in place). It’s a good time to apply some thermal compoundthough so its not a bad thing. I've attached some photo's so you'llknow what to expectshould you decide to take the plunge.
It’s hard to say, it was one of the first things I did. I was more into flying back then so didn’t really take much notice. I'd read many posts on here and other places saying take it off to save over heating so I did. To be fair the weather is only just getting warmer in the UK so after most fights it’s barely warm; however as the ambient temperature warms up I’ve notice a big difference in motor and ESC temperature so I guess for you lucky ones that live in warmer climates its more of an issue.
In conclusion I'd saytaking everything into consideration, as long as your careful not to damage it then it can only be a good thing.
EDIT: OK - Maybe not only a good thing, you could argue you are increasing the chances of something shorting out across that metal heatsink or contacts,but i'd takethe risk
Geez, I'm setting up my new Belt CP with most of the recommended goodies. I'm installing the HS65MG's alot of people seem to use and WOW[X(]you need to do some creative fitting of the chassis to get the elevator and pitch servos in place. I've filed both mounting areas and it's still a very tight fit. Sure don't wantto ruin the leads on the servos installing them. Any tips would be helpfull here.
Can't help you on the CNC head. Thats down the road for me. Just want the things that make it fly better for now....ie gyro, SC and servos.
yeah I'd like to know about a nice gyro/tail servo combo and where I can get it. I'm sure Mike at UsHobbySupply has something. Although the stock Gyro has been great. I havent had any issues with the tail since I set it up correctly.
He sure does have something great: https://www.ushobbysupply.com/produc...63020130d54fb0
This is what I have and this combo rocks! Mike only has 1 left though!
Cheers,
Dave
Cheers,
Dave
Looking at thesecond photo, I havecut the horn down so that it did not catchthe frame below. If ihad this to do again I would fit the servos during the frame build as some will not go in with the frame fixed together.
Bill, I took a look at the Futaba GY401 Gyro and it looks difficult to set-up. It's also about $40 more expensive than the LogicTech 2100T. You really like the Futaba that much more than the LogicTech? I've read that the new Esky 704B HH gyro is a lot better than the previous models and I'm having real good results with it. But then again, I dont know anything else. If I were to switch to something better would you say the difference would be like night and day?
Tell me if you guys think this is worth the money? I was thinking of doing the CNC Head/Tail swap and Xheli has the whole thing for $90. Here's a link: http://www.xheli.com/esbecpcnccod.html
Hey PhillyD, I readjusted my heli so now my Hov. Pit. knob is a little less than half way up. My ESC and lipo temps are way down. I guess with the head speed so low it was putting a ton of stress on the esc/lipo. Im now at 110, where before I was 180. Very nice hahahaha
http://www.cnchelicopter.com/servlet...-CP-CNC/Detail
http://www.cnchelicopter.com/servlet...Belt-CP/Detail
Yes, they cost more but you get what you pay for and all CNCstuff is not created equal. Search this thread and you'll find a lot of earlier discussion about these upgrades. Here's an earlier postof mine with photos of the upgrade. If you're interested in it then follow that thread through the next page for some additional posts on installing it. If you install these upgrades then you could just buy one of their frames and matching gear sets and, mechanically, you would have a high quality TREX clone (which is what I did). I would definitely recommend that you NOT go the Esky CNC parts upgrade route.
Do you know if the parts on this head interchangeable with the Trex450 spares (although I think swash plate is different )?
I'm seriously thinking about building a Trex Clone next - although I will always keep my Belt CP as she'slike part of the family now.
Hey Guys,
Thought I<personname></personname>'d let you know that I<personname></personname>'ll soon be updating my signature from "It<personname></personname>'s a bit like triggers broom now!!" to "It is like triggers broom now!!". [:@]
The final original part (the landing gear) broke this morning. I lost orientation as I flew sidein, backwards into a 180 spin to continue flyingout forwards. I<personname></personname>'ve done this loads of times but this time I came out of the spin banked to one side and a bit far away, my best guess was the wrong guess as to which side and she went almost upside down in normal mode. I almost got her straight and in control before the ground jumped up and hit me. Long grass saved some damage I think as I just broke the landing gear, plastic mounting for CF frame and bent the feathering shaft. Blades and even fly bar still look good to go again. Oh and the canopy has a few more battle scars.
The most annoying part is that I knew I should have stopped. As I flew backwards I could seeshe was not totally horizontal before the spin, I was trying to adjust but went for it anyway. What a clown!! []
Bill,
Cheers,
Dave
Cheers,
Dave
Update: I used a little crazy glue to hold the tail in place. Probably not the best idea but I'm ordering new tail booms and those tail cases I broke so I figured why not. hahaha
Dave, just curious, do you actually own a GY401?
Nope, all I have is the Logictech 2100T - I donated my original stock gyro to the Iraq Fund.
Here is one of the set-up pages I used for the 2100T, which has three nice videos on it: http://www.rcgroups.com/forums/showthread.php?t=737104 This guy thinks that the 2100T is "way more advanced" than the 401 - if you read his first note below the videos. My good experience with the 2100T (just as easy to set up as he shows) has never given me any reason to doubt this - even though I accept that the 401 is a good gyro too. Hard to go wrong with either, once you have them set up correctly...
Enjoy!
Dave
