........."BELT-CP THREAD"........
#1301
NE
RE: ........."BELT-CP THREAD"........
Your welcome. I accidently tightened the motor too tight and some how my holes were off on the plastic mount. And that made the motor rub on the frame and ruined my motor. Now with the aluminum mount the motor is perfectly centered. Just be carefull not to take too much off on one side.
#1302
could someone at this thread help me on another thread?
http://www.rcuniverse.com/forum/m_7302475/tm.htm
I really need help for flybar.
I appreciate that people telling me to research but the problem is... they tell me how it's suppose to look like when it's done. Not HOW TO DO IT
#1303
TX
Hey guys, got a new DX7 and a GY401 for the Belt CP, got it all put together and have a problem with it spinning when spooling up just as it gets light on the skids, in fact it threw the battery out of it because it was spinning so fast. I have tried to reverse the servo with no help there and really don't know what else to do. Any suggestions? Thanks a million.
#1305
My Feedback: (10)
I like not crashing.... Plus I don't gamble especially with remotely piloted lawnmowers
http://www.rc-cam.com/ant_exp.htm
#1306
My Feedback: (10)
ORIGINAL: EricOnTheWeb
Would anyone have the specs for the Esky servo that comes with the Belt CP?..
Weight
Torque
Weight
Torque
#1307
My Feedback: (10)
ORIGINAL: evdreamer
#1308
MO
Hey guys. I'm sorry if this has been mentioned before.
I broke the main gear on my belt cp. I have a replacement gear, but I'm not sure how to swap the one way bearing from the old to the new. Any tips?
#1309
FL
Coolbean, I have changed out several main gears and the best method for removing the one way bearing is to use Dremmel tool. I used a pair of side cutters and cut the fins off exposing only the inner hub. I then used the cutoff wheel and made two lengthwise cuts on the plastic hub then removing the inner aluminum hub. I then made the same cuts on the aluminum housing being careful not to cut too deep so as to not cut the bearing housing itself. This was a fairly simple removal method and the I just used a bench vise to press the bearing into the new gear being careful to put it in the correct way. I don't know if this is the easiest way, but it worked for me.
I just purchased the Align one way bearing removal tool but have not used it yet.
#1311
TX
Coolbean, use a socket that will just fit over the bearing and place it upon top of a vice so that you can knock it through by tapping it. Use this method also to install it, just make sure it is straight when tapping it back in. Goodluck.
#1312
TX
One other thing is to make sure you pay attention to the stamped end of the bearing as to what side it is on so that it works right after installation.
#1313
AL
Hey folks, have read almost this whole thread from start to finish while waiting on my Belt CP. Finally got it today and am ready to plug in my first battery to attempt setup and trimming. Got the ESC unplugged for now to check servos, swashplate level, etc. I remember reading somewhere way back about a couple of people burning up their ESC's by plugging in their battery in idle up mode. After I plug my ESC back in to continue with setup and trim I want to make sure my Tx is not in idle up. Tx is the stock one that comes with the RTF. Can't tell by looking at it or the manual. Can anyone tell me......... up or down? Thanks in advance.
#1314
TX
Make sure the switch is pushed away from you, if your not sure then unplug the motor and watch what the swash plate does when you move the switch forward and backward. In idle up it will move from low on the shaft to higher up on the shaft.
#1316
MO
I actually thought up this method and used it, works great. Had one socket that was bigger than the bearing, but small enough to touch the aluminum ring on the side that the bearing is sticking out of (top of the gear when it is on the heli), then another socket just barely smaller than the bearing on the other and put it in a bench vice. Small socket presses the bearing out of the gear and into the bigger socket. Easy. Then use the bench vice to press the bearing into the new gear.
I did have one problem though. Only the top gear was broken, so I was going to reuse the bottom gear... Well, the plastic part of the top gear that goes into the bottom gear was slightly bigger on the new gear. So when I put the new top gear into the old bottom gear, the plastic rubbed. Used the new bottom gear and it fits perfectly.
#1318
Yeah, that is what I do also, but KA Planes has a tool set of exactly the right dimensions for just over 4 bucks that will make the job even easier, going to get one next order!
#1319
Hello all... another newbie on board
Great forum, look forward to taking part in the conversation!
Currently flying (attempting to fly) a Belt-CP, mixed with misc Align upgrades. I have 4 Towerpro sg-90s running the bird, also looking to upgrade the Esky stock motor and ESC very soon. I just installed a Futuaba 6exh tx as well, so I may have question about that
Happy flying
Dana
Happy flying
Dana
#1320
hi sampler1, im rasputin from heliguy glad to see you around.
i used a jack plug converter and placed it over the old bearing and placed the new gear under it and put in a vice and it pushes the bearing out of the old gear and into the new one. not the easiest way but it works.
ORIGINAL: coolbean
#1323
ORIGINAL: CasualChaos
Your kidding, Just disconnect the linkeage, remove the screw under the gear, pop the shaft up and slide it out. No hacking or cutting. its a 10 minute deal here.
#1324
ORIGINAL: SAMPLER1
So Hows the 6exh in yours?
I just grabbed one. Im intrested Please Tell.....
#1325
So far so good...
I like the fact that once the mechanical portion of setting up the heli is complete there are still so many more fine tune adjustment that can be made through the TX. Adjusting the pitch curve and cyclic movements to max arm swing on the servos, adjust the directional of the servo movement all by pushing a button.
I'm sure there are better tx out there but this definately meet my needs. If I was however buy another I would still stick with Futaba as my brand of chioce, but I would pick up either a 7C or 9C, just to have the extra play with the TX and heli comb).
Thanks for asking, and please share your thoguhts as well
Dana
Dana
