........."BELT-CP THREAD"........
Dave, just curious, do you actually own a GY401?
Nope, all I have is the Logictech 2100T
With all due respect I don't want to get intoa Chevy vs.Ford debate. However,I have used both on the exact same heli and see no real advantage to the Logictech and the 401 isFAR easier to set up (didn't you ever wonder why there are so many set up videos and procedures posted for the Logictech).In fact, if you follow the postings of the guy who made that set up video I think you'll find that he eventually went back to the 401 because of ease of use. My main reason for posting was to point out that for saving $30-40 over the 401 you get no US support location so you're on your own to deal with Logictech in Korea if you have a problem. This is something I didn't know when I brought my Logictech and I thought people would want to be aware of it.
Does the CNC tail also offer the little taps that clip into the tail boom? I some how broke both taps of both sides of the rear tail assembly. Is that normal for the stock plastic tails? What a trip this thing is giving me. I just want to get it set-up so I dont have to worry about anything and can finally enjoy flying it. Let me know guys, Thanks, Joe
Update: I used a little crazy glue to hold the tail in place. Probably not the best idea but I'm ordering new tail booms and those tail cases I broke so I figured why not. hahaha
It would be fun for you to try it for us and report back!
As far as I know the ESC will not stop that. That is because of the drop in revs-drop in tail rotor speed, so you gotta hold more pitch to keep up and that will increase torque.
The tail servo does not need to sub trim until absolutely steady, if it creeps real slowly then that does not seem to matter. I'm guessing the gyro does its job and compensates for a small amount of servo creep.
I believe this is due to a linear drop in the 5v line, even on the bench after 10 mins of power up the tails servo starts to creep.
Kev
Just to jump back to this issue. Even with the new 40A Hobbywing ESC it still happens, so I'm guessing its not just the 5v line. OK it could just be a bad gyro or servo or even justa bad gyro & servo combo. Now I'm looking in more detail. I flew 4 batteries this morning and noticed that each battery seemedtohave a slightly differentresultat full charge and during discharge- which still pushes me towards voltage rather thanany environmental issues like temperature or pressure but I just dont get the link. Why would one battery at 12.30v have one result while another battery at the same voltage have a different result.Off the top of my head I can only think of internal battery resistance. Think I'll have to get this on the bench and produce some good data on voltage / temperature etc.Before I do has anyone seen similar issues before?<o></o>
<o></o>Joey, just a thought, was it your first battery? I’m thinking over-heating and cutting down. Other than that I would suspect Motor or ESC, it could be battery too I guess but that makes less sense.
The real wired one I had and you should perhaps watch out for was a faulty servo. I had two total cut out crashes (i thought interference to be honest). Then eventually all of the servo's started acting really wired on connection, even the RX light was flickering. Process of elimination found if I disconnected one servo everything went back normal. Replaced the servo and all has been OK since. Was this the cause of the total power loss crashes I had? I guess I’ll never know.
Hey Bill, I have the CP V2, is that going to change anything as far as the tail set up goes? I'm looking to order that CNC tail piece later this week and would hate to spend $60 and have it not work for some reason. Hahaha Thanks, Joe
.......I think it may be the motor but I have found that the tail assembly keeps coming loose and the belt becomes alittle jumpy. Going to have to attend to that today and figure something out. Was going to drill the holes out on the frame and install some small nut and bolts. what do you guys think? Will I be creating more problems by doing that? I figured it would hold a lot better than way.
http://www.helidirect.com/hdx450se-t...aa-p-10163.hdx
UPDATE: Mike from UsHobbySupply is getting me this tail assembly. Let me know what you think?
If you want to go with the SX stuff you can get the entire head and tail combo for $110.
Looking at the Head System: http://www.helidirect.com/hdx450se-h...s1-p-10164.hdx
Do you guys know if it'll fit on the CPV2? Because it's a 450 Head et-up, does that mean it'll work?
Oh and I noticed my blade tracking is WAY off. But no matter what I do with the small links connecting the Main Blade Grips to the Bell Mixer Arm it doesn't change. What am I doing wrong here?
I hate to say it but what you're experiencing is a way of life with these darn helis! More time adjusting and repairing than flying.
Don't know exactly what to tell you on the tracking but if it's way off and you can't correct it it usually means there is something loose, broken or out of alignment in the head.Could be a bent feathering or main shaft.Also a bad bearing or something not assembled right in the main blade grips. Anything out of whack in the head assembly can affect blade tracking.
You'll find it eventually!
Bill
........ Anyone have any other tips on finding the cause of thevibration?
If your o-rings are worn or shot, that will affect blade tracking also... Just another thing to check. I'am guessing your heli is still new though, so it may not be the case but thought I'd throw that out there as I came through here snooping around...
Cheers,
~ Jeff
