If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 242 of 250 FirstFirst ... 142192232240241242243244 ... LastLast
Results 6,026 to 6,050 of 6243
  1. #6026
    Tinkman's Avatar
    Join Date
    Aug 2009
    Central Coast, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Hey Philly,
    I'm using these:
    http://www.helidirect.com/align-carb...-450-p-722.hdx
    I'll have to take a look at the grip bearings. When I switched back to the old stock blades, the vibration changed. Now low speed is good, medium is bad ahd high is smooth. The CF blades just got worse the faster I went. That's why I think it's the blades. Switching them effected a change.
    Joaquin
    Belt CP V2, HK 450 MT, HK 500 CMT
    Cessna 182, 195, 310, Spacewalker II
    Futaba 7C
  2. #6027
    phillyD's Avatar
    Join Date
    Jan 2008
    Tortola , VIRGIN ISLANDS (BRITISH)
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Gosh Tinky
    RCU ate my post. I am not gonna try and knock align blades.
    those blade grip bearing may feel smooth in your hand; centripital force will bring out notchyness. Disconnect the pitch slider, pull outward on the blade grips hard and rotate them at the same time. You might feel a notchyness appear.
    Happy hunting that pesky vibe
    Belt CP Day and Night helis, DX6i, 401 gyro, 9257, HS65MG cyc, 30A, CNC 7075 tail/head,Gaui 550 in hughes fuselage quark gyro
  3. #6028
    Tinkman's Avatar
    Join Date
    Aug 2009
    Central Coast, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Hey Philly,
    I got ahold of a digital scale that measures mg. Turns out one of the CF blades was 1090mg and the other was 1170mg! So I sanded the trailing edge of the heavy one till they were exactly the same. MUCH BETTER!
    The only problem was I got a little froggy and crashed into the Bridgeport in the middle of a piro. Of course I got it on video. I'll post it after its done uploading.
    Helis, it's all about the ups and downs!
    Joaquin
    Here you go!
    [youtube]http://www.youtube.com/watch?v=svVctI9evHM[/youtube]
    Futaba 7C
  4. #6029
    phillyD's Avatar
    Join Date
    Jan 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Sir Mr. Tink
    I do ask your humble apologyI liedto you well half way this is on my night heli http://www.helidirect.com/kbdd-596mm...50-p-13436.hdxand I'm not putting what is on my day heli http://www.helidirect.com/esky-plast...2v4-p-2052.hdxNow you nearly got it fixed now you'll get vibes from somewhere else
    That's a mean shop you got there, nice vid..not the crash. Hope you didn't damage much
  5. #6030
    Tinkman's Avatar
    Join Date
    Aug 2009
    Central Coast, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Nice tail blades! Didn't damage much. Just both mains.
    Joaquin
    Futaba 7C
  6. #6031
    Disney1's Avatar
    Join Date
    Nov 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Tinkman I use a Gram Scale with .01 resolution It was less than $20.
    Really helps when when weighing blades to have the extra accruacy.
    Ron.
    EDIT a Miligram scale is great. Much morte accurate than mine.
    The only stupid question is the one you forgot to ask.
    If it\'\'\'\'s not broke don\'\'\'\'t fix it!
  7. #6032
    Join Date
    Sep 2010
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Hi Guys,
    Well at long last I managed to get the new tail assembly on and man is it smooth.
    I got it on Thurs but while I was putting it together a screw snapped that holds the gear box assembly to the tail boom. The guys at Heli direct were great and crossed shipped the part back to me which I received on Sat. I just took it out for it's first flight and after a few minutes of tweaking it flies great.
    Also I found the true reason for my power drop while flying. One of the wires had come loose from the ESC but was staying in place because of the shrink wrap. So when it would loose contact the ESC would kick in and shut things down. I have to get better at my soldering.
    I'm glad I've stuck with this bird because I am really learning a lot. Once I move up to a larger Heli I'll know enough to keep it flying smoothly and safely. [&:] I'm starting to get a squeaking from some where now so I'm going to replace the main shaft bearings and see if that goes the trick.
    Lastly, I'd like to start replacing my cheapo main rotor head a piece at a time and was wondering what would make the biggest difference first.
    Thanks for all your help,
    BD
  8. #6033
    Disney1's Avatar
    Join Date
    Nov 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Afternoon BD:
    There is a bit of a problem doing what you suggest.
    First it will cost twice as much, second you cannot mix and match brands,
    and most importantly you generally cannot mix and match plastic and CNC on the rotor head core.
    The Blade Grips and Rotor head are using a different type of feathering shaft and bearing arrangement.
    What head are you moving to?
    A lot are using the CNC heli head and really like it. Only $73
    Silver  http://www.cnchelicopter.com/servlet...-CP-CNC/Detail
    Blue    http://www.cnchelicopter.com/servlet...-CP-CNC/Detail
  9. #6034
    Tinkman's Avatar
    Join Date
    Aug 2009
    Central Coast, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Hey Biker,
    I agree with Disney. You pretty much have to buy the whole assy. at once. I am using the HDX 450 V3 head, but I found another thread on this forum where people are buying the HK450's. They're sold by Hobby King and are really cheap. I don't have one yet, but it's my understanding that they are very high quality. It's hard to believe for the insanely low price they're asking, but people are swearing by them. You can buy a whole bare bones cnc kit for less than the cost of a head. In fact, some folks are buying the kit just to get the head and tail assys.
    Look into it.
    http://www.hobbyking.com/hobbyking/s...dProduct=12390
    [youtube]http://www.youtube.com/watch?v=0hS_1g9AO3k&feature=player_embedded[/youtube]
    Joaquin
    Futaba 7C
  10. #6035
    Join Date
    Sep 2010
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Wow! very nice...but I'm affraid if I get another kit in the mail my wife will kill me. lol
    I did however book mark the page and will keep an eye on that one.
    Alas, what I really need to do is stop spending and save for a better TX RX and servos.
    This is so addicting it's like crack!
  11. #6036
    Disney1's Avatar
    Join Date
    Nov 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    WOW!!!!
    Holy Cow only $37 for the entier Bare Bones kit!!!
    I can afford to by that and toss the unused parts by sending them to someone for free.
    BD: Buy the kit and get the other parts out of site and use the Rotor head and tail gear box.
    For the price how can you beat it., It is less than half the price of the CHCheli head only and this has a tail gear box too.
  12. #6037
    Tinkman's Avatar
    Join Date
    Aug 2009
    Central Coast, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    No kidding. I'm with both of you. How do I justify getting another 450. But then, how do I justify NOT getting oneat that price!?
    Joaquin
    Futaba 7C
  13. #6038
    Disney1's Avatar
    Join Date
    Nov 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    For that price you could afford to throw the stuff you cannot use in the trash.
  14. #6039
    Tinkman's Avatar
    Join Date
    Aug 2009
    Central Coast, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    OK, so I think I finally got as much vibration out of the camera mount as possible. It took 5 iterations, but I think for as light and cheap as these little cameras are, this is just about as good as its going to get. There just isn't enough mass in the camera or the mount to counter-act all ofthe vibrations. I tried a heavier mount thinking it would help, but the harmonics made it worse.
    So anyway, here's a 3 min. flight with the key fob camera. My blades still need to be tracked, but it's enough to get the point.
    Joaquin
    [youtube]http://www.youtube.com/watch?v=OfizRaOFFVs[/youtube]
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Futaba 7C
  15. #6040
    Disney1's Avatar
    Join Date
    Nov 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Tinkman very nice, smooth.
    You should sell them with teh cvamera and servo as a kit.
  16. #6041
    Tinkman's Avatar
    Join Date
    Aug 2009
    Central Coast, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Not a bad idea Disney.
    At this point thoughI'm just not sure I want to invest in that much stock for an idea that may or may not go anywhere. For now I figure anyone with a key cam and Belt CP will already have most of the stuff laying around. They're not going to want to shell out $50.00 for a camera mount when they already have the 20.00 cam and a spare9.00 servo sitting in their toolbox. I really want to keep the price down foranyone who's interested. If this suddenly takes off though, I'd certainly invest in the overhead.
    I currently have hangers configuredfor the Belt CP and HK 450.
    Joaquin
    Futaba 7C
  17. #6042
    phillyD's Avatar
    Join Date
    Jan 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    That's not nice. I check everyday nothing-no post I turn my eyes for one second now I gotta catch up.
    Will edit this post soon
    Wowsers Sir Tink
    That is the epoch of vibration free. Well done Sir. I gotta see what you did to the mount and do mine when I get it. Really nice,,sweet
  18. #6043
    Join Date
    Sep 2010
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    You guys are funny...but...Hmmm...
    Whats the diff between mode 1 and mode 2 on TXs ?
  19. #6044
    phillyD's Avatar
    Join Date
    Jan 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Mode 1 throttle on the right stick(european) Mode 2 what we use throttle on the left
  20. #6045
    Tinkman's Avatar
    Join Date
    Aug 2009
    Central Coast, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Thank you Philly,
    It took several tries to get it like that. I'll post a photo.
    I went with an aluminum hanger and mounting blocks for the shoulder screw and servo, and kept the camera mount nylon.
    Joaquin
    Futaba 7C
  21. #6046
    Join Date
    Sep 2010
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Holy Mackeral...what is up wit the screws that are in with the Align tail sets? I had another screw break in the same way as before.
    Now stop me if I'm wrong, but if I was over torquing the screw wouldn't the aluminum strip out before the screw breaks?
    This is the second time that the exact same thing has happened.
    The bad thing is that it breaks off inside the tail assembly. There is nothing I can do but send the part back again.
    Do you guys think that they will give me grief about this? I've never really dealt with them over parts issues.
  22. #6047
    Disney1's Avatar
    Join Date
    Nov 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Hey BD:
    It is a new on for me too. The screws must be very brittle.
    Do you have a Local Hobby shop near you?
    If so replace the screws on the new oone before you build it.
  23. #6048
    phillyD's Avatar
    Join Date
    Jan 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Yea Biker
    You might be over torquing, and folks do what Disney said; also let the loctite do its job.Some aluminium assemblies seems to be harderthan the align screws. I have had that. Lucky me though the head comes off and leave a piece for me to pinch with a small visegrip, and take 15 minutes toget it out. Post a pic ifyou still have an example, so we might see a solution to get the screw out. I've had one left in the flybar cage rod
  24. #6049
    Join Date
    Sep 2010
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    Yeah...there's not going to be any getting this screw out. The screws are indeed very brittle. The only way to get it out would be to drill it and as small as it is it would be impossible to say the least.
    I went with the sport gear box instead of the SE and the screws that attach it to the tail boom are really long. I liked the way the sport was built from the pictures I thought it might be a better one. Plus it was a little cheaper. (DOH)! my mistake. I'm either going to try and exchange it for the
    HS1259-84 - Trex450SE and pay the difference, or have them refund my money and see if I can find the HS1259-84 - Trex450SE locally.
    I'm really getting frustrated with the whole tail rotor thing.
    Aside from the screw breaking and the gear box not being able to be tightened the heli was flying great. The thing that bugs me is that I never really got one flight out of it without the second screw breaking. I had the gear box on, used loctite, didn't over tighten and things seemed to be alright until I noticed that the rotor blades were cocked to one side. The first time I thought it was just a loose screw so I just snugged them up, or so I thought. Then I noticed it again and thats when I realized what had happened.
    Anyways thats whats up.
    So back to the drawing board, wait several more days and try again.
  25. #6050
    Join Date
    Sep 2010
    Tampa, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: .........
    I tried to get some pics but I'm not sure they will do much good.
ID:	1581159   Click image for larger version.
ID:	1581160   Click image for larger version.
ID:	1581161   Click image for larger version.
ID:	1581162   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
