Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
Belt CP Upgrade to full CF and CNC
Reply
Old 01-28-2008, 10:27 PM
  #51
OHaussie
OHaussie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Belt CP Upgrade to full CF and CNC
Nice work Evdreamer,
You know now, those Yellow plastic parts have to go !!! they just don't suit the airframe any more...LOL !!!
cheers,
Brett
Oh and on a side note ( still related to this thread) on my Belt-CP, can I fit the CNC blade grips to my plastic head (the one on my helicopter, not my shoulders...) ??
OHaussie is offline
Old 01-29-2008, 12:10 AM
  #52
evdreamer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have read on websites it won't fit but I haven't tried it. My plastic head is all torn apart and I don't really remember how to put it back together. Oh well I shouldn't need it now. The only reason I kept the yellow fins is because I thought I could see it better than the black carbon fiber ones.
evdreamer is offline
Old 02-06-2008, 02:44 AM
  #53
evdreamer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the Carbon fiber frame but I couldn't get an upper right frame that worked. I got 3 of them and all of them are different sizes and different size holes. I just went back to the stock one. So it has the aluminum head assembly, tail assembly, carbon fiber boom, align 35A ESC, and Rotortech blades. I would like to have it up in the air in the next couple of days.
ID:	871311   Click image for larger version
ID:	871312   Click image for larger version
Old 02-08-2008, 04:41 PM
  #54
Druss
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just as an update. This is back on the selling block. Got myself a Hirobo Lepton EX and this has to go to fund it.
Druss is offline
Old 02-08-2008, 05:18 PM
  #55
OHaussie
OHaussie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Druss..
What $ are you looking for??
OHaussie is offline
Old 02-08-2008, 05:40 PM
  #56
Druss
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got it listed for $450 RTF w/ the esky transmiter and receiver or the AR7000 if you have a DX7. If you have your own electronics then I can start taking things off and reducing the price.
Take a look.
http://www.rcuniverse.com/market/item.cfm?itemId=366270
Druss is offline
Old 03-13-2008, 12:40 PM
  #57
Claudius2k
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please Help
I completed the Belt CP alloy tail rotor upgrade. When I went to remount the tail servo arm on the boom, I appear to be missing the pivot cap screw which goes through the 2 bearings. The triangular boom mounted bracket appears to be threaded. I tried a 2 x 12mm screw and it was too small. I tried a 2.5 x 12mm screw and it was too large. What size could this screw be? I don't even see it in the pictures of the upgrade packages. Please help, what size is this screw?
Claudius2k is offline
Old 03-13-2008, 02:06 PM
  #58
evdreamer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the cap screw you are talking about came off the stock piece. It is a long black screw. Then the triangle mount uses two small silver screws that have a phillips head cut into them.
Old 03-13-2008, 04:45 PM
  #59
Claudius2k
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks very much for replying. I have 2 long black caps screws left 12mm long. They are 2 mm and they slide right through the threaded hole. I tried adding a nut but it really binds the bearing.
Old 03-13-2008, 05:00 PM
  #60
evdreamer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My black screw is around 12mm. I can't get an exact measurement because it is still in the tail. I don't use a nut on mine. I just put lock-tite on it and it hasn't backed out for over 65 flights.
Old 03-13-2008, 11:34 PM
  #61
Claudius2k
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks much for posting the picture. I know from other thread discussions there were a couple of versions of these parts. The bearing hole is definitely 2mm. So my bracket must have been intended for use with a nut. That is what I tried only I put 2 nuts on with thread lock, no washers and it seems to work. Thanks so much for your help....
Regards, Mark :-)
Old 03-14-2008, 01:31 PM
  #62
evdreamer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your welcome. I had no idea there were two versions out there.
