Belt cp pitch adjustment
The belt cp does not have adjustable links on the top like other helicopters do . How do I adjust the pitch witout messin up the tracking? I might be adjusting the wrong linkage. I am using the linkage that is attached to the swashplate airleron is that the way?
AB, CANADA
RE: Belt cp pitch adjustment
ya, that's the only way to do it...
what you do is set the pitch on the "master blade" then change the tracking on the other blade until it matches, the pitch on both blades should be the same once you're done.
AB, CANADA
slide the pitch gauge onto the blade and move the sliding piece over to hold it in place. then move change the pitch on the gauge until the top edge of the pitch gauge is level with the flybar.
