No Tail Hold - puzzled
BC, CANADA
Did a replace of the stock belt pulley on the hbk2 with the 43t pulley and a new 3900 motor. I have moved the gyro back and forth along the boom and can't get the tail to hold. I can get it to spin like a clock in both directions slowly at about one third of throttle. Any higher and the tail loses authority completely and the tail spins like a fan. I can hold the tail with a little rudder until I get to about 1/2 throttle and then it breaks loose again. Right now when I get to about 1/2 throttle it will spin CW rapidly and I can stop it with rudder but then it will spin CCW rapidly until I stop it with rudder and then it does the spin in that direction...
Wots wrong?? I don't touch the heli at all when I plug it in. I level the blades before I plug it in and when it spins up.... it spins.
My Feedback: (20)
RE: No Tail Hold - puzzled
You might want to check the tail had the same problem and It was my tail rotor was on backwards, so I took the set screw out flipped the whole rotor and that was it ....
TX
ORIGINAL: Fly To Chill
What kind of GYRO?
BC, CANADA
Stock gyro... nothing was backwards but I found someone who has some crazy helo skills and took it to him to help me sort out the problem. Turns out the gain was a tad off so the gyro wasn't reacting quick enough and I was moving the servo to much. I thought I wasn't, at a mil at a time kinda thing but it has to be even less when dialing the tail in... on mine it seems anyway. So now my birds flys... is pretty stable with a slow CW turn but I'm goign to tweak it ever so slowly to see if I can't get it more solid on the tail.. Guess a head lock gyro is needed in the future here. That or a T-Rex...
