Where to but Lipo plastic wrap?
MI
I need to take the plastic off my ESKY batteries to reconnect one of the balancer wires (the yellow wire fell off both my esky 1500 15c's) and wanted to know where to buy some or what would be a good alternative.
Rosebud6
Rosebud6
RE: Where to but Lipo plastic wrap?
Hi Rosebud6
I use heat shrink tubing for battery wires you slide it over the wires you want to protect and heat it lightly and it shrinks to form a coating....you can get it here
http://www.hobby-lobby.com/connectors.htm
or Radio shack sells it ... http://www.radioshack.com/sm-36-piec...i-2062662.html
if you need wrap for the battery packs which i never had to do but did some searching and found this for you
http://www.batteryspace.com/index.as...S&Category=962
If you need the wires you can find them here
http://www.helidirect.com/index.php?cPath=88
Good Luck,
Rich
Good Luck,
Rich
MI
Thanks Rich. I have heat shrink tube. Just needed the plastic wrap for the batteries as I have to take it partially off to soldier the wire back on and would rather fix it right rather than just tape it or something.
