43t belt upgrade questions
Hey guys just upgraded my HBK2 belt to the 43t upgrade. Herd a lot of good things about this upgrade but found some things questionable. I know it ads a lot of power to your tail for more control but my tail now is extremely touchy. Is this normal. Do I just need to relearn how to control my tail with the new belt. I still have the rate gyro. Im looking at the telebee hh duel rate gyro to give me some more stability with my tail. Also this is not really a problem but for some reason after installing the belt I had to reverse my tail servo. The yaw motions were reversed.
MD
RE: 43t belt upgrade questions
If you had to reverse your tail servo, then you got the belt twisted the wrong way. You may also want to move to a hole closer to the center of the horn to reduce touchy-ness.
M
M
VA
I twisted my belt up a few times when I was replacing the tail boom and putting on the 43T pulley, until Z finally told me that the diagram in the HBK2 manual even shows it backwards! Hard to see how that is a translation error from Chinese!
Agree with Michael, your belt is twisted.
Cheers,
Dave
Cheers,
Dave
BC, CANADA
Agreed... most likely a twisted belt... Has to come up into the rotor wash... It will get more responsive after the install... when you want a new gyro buy the g401b from cnchelicopter... its better and cheaper than the Telebee...
happy fly'n
