Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Esky Helicopters
Reload this Page >
Body spinning on Big Lama
Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
Old 01-07-2011, 01:38 PM
Skymaster337
My Feedback: (10)
Default Body spinning on Big Lama
Just purchased a used E-Sky Big Lama which is a brushless conversion from RC711. Transmitter E Sky ET4 dip swithes (Ail up) (ele up) (thr down) (rud down). On spool up heli lifts, fuse rotates as soon as enough throttle is given for lift. At very low throttle have left and right rudder control, slightly more throttle and body spins. any idea's on what to look for would be appreciated.
George
Old 01-13-2011, 01:20 AM
bladeskiller
Default RE: Body spinning on Big Lama
Does the heli spin like crazy just after leaving the ground? If gain trim on 3 in 1 is set properly it could be a gyro compensation reversal due to wrong connections on 3 in 1 unit. Try this. Change the positions of the two motor drive connectors on the 3 in 1 unit (the red connectors) , change position of RUD switch on your transmitter and try again.
Old 01-13-2011, 11:39 AM
Skymaster337
My Feedback: (10)
Appreciate the responce . . . reversed the motor leads on 3 in one and now gyro hods like it should.Part of the fun of buying used with no schematics . .
