Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Esky Helicopters
Reload this Page >
Belt CP V2 lifts off then lands at maximum throttle...
Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
Reply
Old 01-27-2010, 12:34 AM
sorka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Belt CP V2 lifts off then lands at maximum throttle...
Got new Belt CP V2. Charged battery. Attempted to check tracking, but motor wouldn't turn over. Only klinked and jerked. Checked belt tension which seemed fine and not too tight. However, I loosened it anyways to the point where you can push the belt in where you check the tension all the way to the other side so the inner belt teeth are touch the inner belt teeth on the other side.
At this point, it would turn over, but only at about 80% throttle. Anything before that just results in klinks and jerks.
Items checked:
Battery Voltage 12.6 volts.
Pitch +9 degrees in normal mode throttle all the way up trim all the way down with motor disconnected.
Tracking. Minor adjustment and it was perfect.
Swash plate level.
Rotor assembly turns easily but I don't have another one just like it to compare.
Also, when I power up and bind, most of the time there are no beeps yet the controll does bind and the controls work. Sometimes I get one beep. Occasionlly I get two. And rarely, only twice, I got 3 beeps a high, low, and high beep.
When I spool up, it klinks and jerks until I hit about 80% throttle and then it violiently spins up rotating the entire heli in the oposite direciton about 180 degrees. I can somwhat mitigate this by anticipating it as it jumps and lower the throttle to about 30%.
At this point, it takes about 80% throttle to lift off and 100% to get it above 3 or 4 feet where it escapes ground effects. However, at this point, even with 100% throttle, it just settles right back down the ground.
By comparison, I flew a new Eagle 50 the next day and it is a rocket. Takes off at about 30% throttle. Much higher RPM than the Belt was.
At this point, the only thing I can think is that either the ESC or motor is bad. The fact that I rarely get the 3 beeps might be a clue.
However, a meter shows 0.5 Ohms between any 2 of the 3 wires, so it doesn't seem to be a damaged coil.
The ESC shows 32 K Ohms between any 3 wires.
sorka is offline
Old 01-27-2010, 08:58 AM
icjefferys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Belt CP V2 lifts off then lands at maximum throttle...
From my 1 week so far of Belt CP experience, the beeps only come when the ESC is hooked up, so no or not enough beeps may indicate a bad ESC connection or a bad ESC. I think you can discount belt tightness as a cause. I don't know anything about Ohms!
icjefferys is offline
Old 01-27-2010, 09:14 AM
barak1001
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's sounds like one of the wires on your ESC has a bad solder joint or a break in the wire.
barak1001 is offline
Old 01-27-2010, 12:25 PM
Disney1
Disney1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It could be a defective ESC the Esky ESC is notorious for catching fire in mid flight.
Poof Roasted Belt CP
This is what I use: https://www.ushobbysupply.com/produc...roducts_id=425
Disney1 is offline
Old 01-27-2010, 01:47 PM
sorka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Xheli has RMAed the motor and the ESC. I removed the 4 screws that hold the motor plate in but can't get the darn thing out. I don't want to force it.
Anyone know the proper procedure for prying it out?
sorka is offline
Old 01-31-2010, 07:58 PM
choppersrule
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorka,
I don't have a Belt CP, however, some of the 450 size helis, their motor mount has two small tabs, that slip into the frame, one on each side. You may have to loosen or even remove some of the frame screws in the motor mount area, to get the motor mount removed.
Dave
ORIGINAL: sorka
choppersrule is offline
Old 01-31-2010, 08:04 PM
sorka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually, just gently pulling on the halves seperated about a mm and the whole thing just slid out.
Turns out it was the ESC. When I had the motor out, I decided to see what it would do when not driving rotor assembly. Again, it took about 80%throttle to get it spinning. Up to that point, the motor would klink. Once it started spinning it would alternate between really high RPM, really low RPM, and something inbetween where it jerked violently. At this point the ESC smoked, popped, and then caught fire.
sorka is offline
Old 01-31-2010, 08:13 PM
choppersrule
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorka,
Glad ya got the motor mount removed. Sorry about the ESC catching fire, on the plus side it will be replace by Xheli and it didn't happen in flight where a lot more damage may have occurred.
Dave
Old 01-31-2010, 08:42 PM
Disney1
Disney1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think I said this earlier.
Poof Fried Heli.
Normal for the Esky ESC
Your replacement will probably also be a Esky ESC same fire hazard.
Disney1 is offline
Old 02-01-2010, 05:57 PM
46u
46u's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First thing I did with my V1 was replace the ESC before I ever put power to it do to all I read about them. I could not even get $5 for my stock one on eBay.[X(] I am running the Hobby Wing 30amp.
46u is offline
Old 02-01-2010, 06:44 PM
Kelownan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man that sounds alot like the issues i had with a brand new brushless motor for my King2 it would make sounds like an old dialup modem. and i had a 30amp tower pro esc onboard.
Mike at USHobby supply replaced the motor and my problems went away.
so yeah if you have the money a castle creations or hobbywing ESC is good, i have also tried out the Storm30amp ESC.
(the one that comes with the Storm450 at "helipal" i think)
its 3times cooler running than my tower pro and has way more features, the price is also a winner. its worth checking out.
Kelownan is offline
Old 02-02-2010, 04:20 AM
Navy_1
Navy_1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i use the DYS 30A it runs my great. the ESC is a big issue
https://www.ushobbysupply.com/produc...oducts_id=1014
Belt-CP V1 - DYS-30A ESC - Telebee V2 DX7
Navy_1 is offline
