Tail rotor pulley.
Tail rotor pulley.
I've been having an on again off again problem with my tail rotor. You see, whenever I have an oops and the tail rotor blades strike something the belt gets loose and when I tighten the belt up it'll go from being tight to jamming. I figured out that the rear pully is either out of round or the hole in the center of the pulley is offset like in a cam shaft. It seems that both my HBK2's (I have a second one for parts) have the same problem.
Cwoodkiter
Cwoodkiter
CA
RE: Tail rotor pulley.
I don't know about the HBK2, but if its the same as the Belt CP the guide pulley rides right on the threads of the screw holding it in place. That really cuts into the aluminum pulley over time. I'm thinking that's probably what your problem is. I'd consider an aluminum upgrade, but until then maybe order a couple new pullies,
Joaquin
Joaquin
