MARZ 2.5
#52
MARZ instructions - as supplied with engines sold by RJL/Mecoa.
Also supplied with the engine: Mounting hardware (in wax paper packet), short length of opaque fuel tubing and white nylon 8 x 4 propeller
#53
Drop that back to 35% and replace with kerosene. 10% mineral oil and 10% castor should be OK, though I do wonder why this is specified.
DF
#54
maybe there is an other sheet the one Fiery sheet shows is the 1/3 1/3 1/3rd mix
also may be an old wives tale read somewheres that old nylon could dry out and get brittle the suggestion was to boil in water for
15 minutes martin
confusing top of sheet reads 50% indeed bottom 1/3 on ether
15 minutes martin
