Recommend a carb for my PAW .06
RE: Recommend a carb for my PAW .06
My PAW .06 came with an airbleed carb. It works fine. It's not adjustable, but who cares? The airbleed carbs on all my glows, including all my Enyas, are wide open anyway.
If the spraybar in the PAW carb is not aligned properly, the carb doesn't work well. If it is aligned properly, it does.
Jim
Jim
ORIGINAL: Mr Cox
If the barrel is too loose it is fairly easy to just make a new one with a tighter fit. I have and old PAW 09 where the carb body is aluminium and barrel has worked its way through out the years, making the hole a little larger. A plastic barrel seals better, PEEK is nice to work with and Teflon works too.
This is the best idea yet-we have a ton of plastic at work, mostly Delrin and Nylon. Don't know which would be better from a fuel-proof standpoint but would be a doddle to make.
