Priming with ether is not strictly neccesary..
RE: Priming with ether is not strictly neccesary..
Jens I think the Ignition improver will make this fuel real good , of course we are waiting for your experiment , and I will try it sometime , its a nice experiment
Can you advise on 20%, in the gasoline /Kero , fuel mix ,,, ordinary 2 stroke , ( weed eater oil ),
would that be better or worse than 20/50 weight motor oil
on second thought I will stick with castor
oil because when everything goes bad it will save my conrod every time ,
My Feedback: (19)
My four stroke diesel knock when the settings aren't just right. My wooden test bench however makes it sounds alarming, and on video you'd think the rod is going to blow the the crankcase any second. I here similar sounds in the video. I'd say there is some knock, but based on my experiences it's difficult to say how bad it really is. I don't think I've run any two strokes that had significant knock, but I haven't run them without ether.
I find that etherless mixes are critical on settings.
My Feedback: (19)
Oh some posts snuck in.
DII will probably not improve the knocking.
If you use a two stroke oil, look up that technical data sheet and choose a high viscosity oil. Many two stroke oils are of very low viscosity compared to castor.
ORIGINAL: gkamysz
We must live with the strange sounds coming out of the movie when the real sound that is heard through the ear showed that the engine was in order. My neighbor said that my engine was smooth and nice ..
#31
My guess too would be the motor test stand acting as a sound board. The engine sounds slightly laboring, but that is only to be expected when using nil ether!! IPN should solve that.
Jens, what happens if you mix castor and gasoline first, and then add the kerosene?
#32
ORIGINAL: pe reivers
The polarity of the atoms that make kerosene / gasoline will not let the mix with castor oil. Ether or other additives that have both polarity both in positive and negative charged atom that makes it possible to get both fluids mixed together. I learned at school in chemistry hours in secondary school.
#33
I dont have any problem using gasoline kero and say R40 Castrol , I will run that
but how much ignition improver to add?????? that is the next big question to be answered
#34
As to the wooden platform on the test stand, that is what, about 1 1/2 inches thick?
I honestly doubt that much drumming noise is coming from there as its quite thick enough - I mean nothing on a model is going to be anywhere near as solid so the noise being heard is quite realistic.
And the real test of the fuels useability would be as Pe´ says MTBF or Mean Time between Failure and as Ray mentions, the conrod would be the litmus indicator.
#36
ORIGINAL: 123Cat
The function of the ignition improver is to reduce "ignition lagg" and thereby give smooth, powerful running. Very little ignition improver is needed for this purpose, the precise amount depending on the particular fuel formulation, and is a matter for experiment in each case. Seldom is more than 3 % required, and the model diesel engine owner would be well advised to start with about 1% of ignition improver and gradually increase, by not more than 1/2% at a time up to a maximum of about 2 1/2%, until smooth even running is obtained -and then to stop. This is a case of " a little of what you fancy does you good" -but a little more can play hell.
It's raining out there that I have not experimented with fuel with the ignition improver. And in addition I must buy a starter motor and testing start willingness of the engine and learn out the fuel are likely to ignite in a short time (the electric drill does not go more than 1400 revolutions per minute).
#37
Jens I have an article that says a plain bearing hydrodynamic bearing can have 6000PSI of oil pressure generated
#38
ORIGINAL: 123Cat
Yesterday i bought the electric engine starter. And i am planning to compare difference fuels and learn out which fuel is good for start willingness in a cold engine. Without and with IPN and more or less gasoline in kerosene depending on viscosity in fuel affected by how good is the atomizing the fuel in the engine. Good atomized fuel means smaller fuel drops to heat up quickly as possible by heat of compression.
#39
Today i took 3 movies of the engine running with IPN in fuel, also 3 difference fuel with 2% IPN (Methyl Ethylene Ketone Peroxide, glassfibre hardener).
The diesel engine who is cold was easy to start up with electric engine starter.
I noticed that the fuel with castor oil was a little different than other fuel with motoroil oil, engine needed a little more compression and the carb had to be adjusted again. Otherwise it was easy to start a cold engine with castor oil as lubricant.
[youtube]http://www.youtube.com/watch?v=7BogcI5cshE[/youtube]
[youtube]http://www.youtube.com/watch?v=5Q0RBgmPRbE[/youtube]
[youtube]http://www.youtube.com/watch?v=aM0LrlSAIOs[/youtube]
#40
Question??? How much compression increase is required over the ether based fuel to get ignition of the mixture
Ignition improver is usally a nitrate MEKP is hazardous, a drop in the eye can cause blindness
But back to the original question , If the engine required a very large increase in compression for running will this not put undue stress on it rod and crankpin beyond its design parameters and shorten its life??
most engines running on an ether based fuel the compression is only slightly more than glow martin
#41
Im really surprised that it starts so easy on the Gasoline , Kero and Castor and IPN
Nice video and well done,,
And the engine sounded good
#42
Ok again how much higher does the compression have to be increased to achieve this?? my concern are we exceeding
the safe limits for the engine, in other words overcompressed beyond its design limits martin
#45
ORIGINAL: AMB
I can measure how much is compression ratio calculated by treads on contra piston screw when the cylinder bore/stroke is known and compare with fuel both with/without ether. Then i can write the resoults of compression ratio contra fuel mix here next time.
She's a gonna blow soon
Sad to ruin the engine
#46
ORIGINAL: gkamysz
Jens, it looks like temperature is about 17°C, is that the case?
#47
ORIGINAL: locktite401
Could not find parts damaged or show signs of abnormal wear after many hours of driving with motor oil and castor oil since the engine was made in 2005.
Nor are the holes in the moving parts become oval of knocking or used by only motor oil in the periods I had not obtained castor oil. Both the piston pin and Crankpins is in order.
I post pictures of engine parts that you can study on engine parts.
