No Improver
No Improver
Ran out of Ign improver , and I want to fly on Sat , what can I use in an emergency , Vegimite , Petrol , dishwashing liquid,Ligroin, Iso butyl methyl ketone , Octanol-(1) rein ,,, Ethyl acetate , amyl acetate,, Dicloromethane
Maybe I could mix them all together and make a new compound ?
RE: No Improver
And Chloroform too , Your right I will just do without , I have some MEKP , but , I dont really want to
What is the key to the ignition improver,,,,, the ignition temperature ?? ?
RE: No Improver
ORIGINAL: 123Cat
RE: No Improver
remember that some of the substitutes for Amyl Nitrate are very corrosive so you might want to flush the engine with kerosene and oil it after running.
George
George
RE: No Improver
Is acquiring some Amsoil Cetane Boost (2-EHN) out of the question? Did you call the Aussie distributor to see if there is a local stockist?
Have you checked with some local T/R or combat flyers? Ask politely and I am sure someone would have some to spare ...
RE: No Improver
ORIGINAL: 123Cat
Ive got some Amsoil on the way, may take a week or so .
In the meanwhile try some Wombat urine. Actually it's very rich in complex Nitrate compounds.
You do need about 5% for it to be effective but otherwise it works really well.
Should be easy to get out your way with all those Wombat Studs around.
RE: No Improver
Ive enough Improver for a 0.025 % mix , so I will run that, I think that it would be safe to run 2% WD40 , after reading some of Andy W posts but nothing else
RE: No Improver
I'm not sure that this will help you, but ... use the Cetane improvers that are sold for use in diesel-engined cars. Many garages will stock these; I presume you don't live a hundred miles from the nearest decent garage.
My Feedback: (71)
NH
RE: No Improver
Funny you should mention WD40 123Cat. I’ve had more than one engine start for a few seconds while turning it over to spread the WD40 throughout the insides. Great fun while holding them in your hand in the kitchen in front of the Missis.
RE: No Improver
Well, Cat, at least you have high Summer this time of year... DII is less critical in comfortable warm weather, tho still a lot of help.
Luck! I wonder what the postal and import authorities would think - or worse: do - if the sniffer dogs alerted to a packet of Wombat Urine... You have a death penalty down there for criminal convicts? (No offense intended......)
RE: No Improver
Hi Lou
Its been cold here when I fly mornings ; Jumper weather ,so its rough and hard to tune and partly worn which makes it even harder to tune
RE: No Improver
ORIGINAL: Lou Crane
No death penalty in Australia since the mid 60's.
G
