NEED INFO ON A SUPER ELIA DIESEL ENGINEMADE IN ITALY
HI
DOES ANYONE OUT THERE KNOW ANYTHING ABOUT THIS BRAND OF ENGINE
ANY HELP IS GREATLY APPRECIATED IN ADVANCE
BEST REGARDS TONY
BEST REGARDS TONY
RE: NEED INFO ON A SUPER ELIA DIESEL ENGINEMADE IN ITALY
very good history on GOOGLE just put in Elia model diesel engine, it comes up, they made glow, spark and diesels and replicas also made in Italy martin
http://www.rojobcn.com/technic/avion/elia6d.htm
http://www.rojobcn.com/technic/avion/elia6benz.htm
http://www.rojobcn.com/technic/avion/eliatitano.htm
HI CORIOLAN
mine looks most like the one in the bottom last picture-only i do not have the fuel tank on mine ( brass tank )-looks like my tank would be independent of the engine
do you have any idea which prop size it would swingmine is the diesel typenot a spark plug
thank you for helping me identify this engine
this would be the first diesel engine i would be attemping to run in the future running glo stuff for 26 years
my very best regards enjoy TONY
AMB AND FIERY
thank you for you help identuifying this engine
AMBfound some good diesel info on google -rcgroupsantique diesel enginesneed to look at more of that soon
FIERYi could not open your info but thank you
best regards TONY
best regards TONY
tony the site Fiery put on is fine pulled it up identical to the google post
RC universe has some glitchs now and then, I would get error messages 403, 405 or a complete drop out, sometimes on posting . loading pix etc martin
The ELIA TITANO is 4cc(.25)and long stroke like most side port of that period (1946) so it will swing a large prop with more pitch than a glow equivalent at a much lower rpm. Ma first diesel engine(a long time ago)was a French Stab 1.25cc and it was swinging a 10"X6" without problem on equal parts of ether/Kerosene and castor oil!
HI CORIOLAN
my engine is the SUPER ELIA no fuel bowl
do you have any details on that particular engine or know were i can find the details
i can post a picture if it will be of some help
i have no idea of how the ELIA TITANO'S SPEC'S might relate to the engine i have, all due respect
the help you have given so far is priceless to me as i have no idea what i have
but getting much closer with your help
best regards TONY
best regards TONY
Do not forget to look at the "Ambrosi e Gattafoni" website.
These two Italian gentlemen produce the most spectacular reproductions one one-off miniature engineering projects that you are ever likely to see. The focus is on internal combustion with many diesel variants represented.
From memory, there are a couple of ELIA engines there too!
ST86.pdf (sticksandtissue.yolasite.com)
