OPS 30 Maxi and 60 Twin
My Feedback: (90)
RE: OPS 30 Maxi and 60 Twin
I ran both of these as glow. They were never diesel. Neither OPS or Bob Davis offered them as such. The twin was one of the loudest large engines I ever ran. Though they look huge if you put a ST3000 next to it it will be about the same size. The excess finning gave it that large appearance.
Here is a old thread about them.
http://www.rcuniverse.com/forum/m_30...tm.htm#3057090
http://www.rcgroups.com/forums/showthread.php?t=961167
It has a roller or needle bearings on the connecting rod too. It seems to do well converted to gasoline as well.
Since it has a Walbro like carb on it, the fuel pump can be most anywhere. It can run lower oil percentages in the fuel with the rod like that.
10% to 12% oil seems to be what they like to use, little to low nitromethane percentages.
They have one at our local hobby shop that I keep eyeing everytime I go into it.
My Feedback: (90)
ORIGINAL: N99JH
Dennis
How did you like the twin? Was it powerful? Fuel guzzler? What size prop would you recommend?
Joshua
Dennis
Joshua
