Everything Diesel Discuss R/C Diesel engines here.
Variable RC Diesel head for Cox .049
Reply
Old 07-01-2012, 05:52 AM
Dan Vincent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Variable RC Diesel head for Cox .049
I have this Davis Diesel conversion head for Cox .049 & .051 engines that has a variable R/C arm.
There is an "O" ring on the screw and when it gets oily, it slips. I've never seen another one so it may be a short run item.
Just wondering if this thing worked or am I using it wrong.
Hope Bob Davis will check in on this one and give some info.
ID:	1777405   Click image for larger version
Dan Vincent is offline
Old 07-03-2012, 11:40 AM
ddd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Variable RC Diesel head for Cox .049
Wash the O-ring, it should not normaly get oily. You loosen it adjust compression then tighten it for servo control. We made hundereds of them as R/C was not ready for more then two channels at the time.
ddd is offline
Old 07-03-2012, 12:47 PM
RDJeff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll be watching this one, as I picked one up a while back that is brand new.
RDJeff is offline
Old 07-03-2012, 04:08 PM
Dan Vincent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info Bob.
It seems like a good idea now, with all the light-weight radio gear on the market.
What kind of RPM drop can I expect when the compression is backed off? I know it doesn't take much power drop to get most 1/2A's to lose altitude.
Old 07-03-2012, 07:05 PM
Jim Thomerson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an Indian Mills .75 which starts and runs nicely. I have to hold the compression screw in place running it on the bench. I has planned to replace the compression screw with a larger set screw. However, I may actually take up flying RC and use the Mills with the compression screw as the throttle. One never knows. [8D]
Jim Thomerson is offline
Old 07-04-2012, 05:13 AM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DAN if I remember my conversation correctly a few months back when he got my back into the cox 049 and or 051 , that 1ittle back off on the compression drops the rpm about 50% or more maybe to around 6K ??? or so, no way will the plane stay in the air on that reduced thrust just land it martin
Post note "he" was Bob Davis
AMB is offline
Old 07-08-2012, 05:22 PM
Dan Vincent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Martin, that should be enough for landing a 1/2A. I'm visualizing a 1/2A float plane doing touch and goes.
Contact Us Archive Advertising Cookie Policy
