If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 6 of 6
  1. #1
    Join Date
    Jun 2003
    winter park, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ASP 21 conversion
    Jut found this lurking in a box, It is a series A, ASP. not the latest head reads AJC/JEN 2005 so came from Just Engines UK back then will crank up sometime
    hmmmm 3 tries finally a sharp pic martin
    should be interesting how it compares to the irvine 20 in a run which did 9200 on ZINGER 10X6
    GAME TIME GUESS'S GUYS
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1820561   Click image for larger version.
ID:	1820562   Click image for larger version.
  2. #2
    Join Date
    Jun 2003
    winter park, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ASP 21 conversion
    well took it out to the garage and bolted on the stand mounted the 10x6 zinger too dark to open door tach and run but a few drops down the carb and after about 10 flips off it went
    tried this again with a few drops roared off, did this 3 times instant start 1 flip tomorrow am the run martin
  3. #3
    Join Date
    Feb 2002
    Hervey Bay Queensland, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm in
    Top RPM: 10,100 on the above mentioned propeller
  4. #4
    Join Date
    Jun 2003
    winter park, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have good vibes on this one, in the test starts no kickback martin
  5. #5
    Join Date
    Feb 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I would not be surprised if the little .21 exceeds expectations.
    My ASP diesel conversions run well, particularly the .32A.
  6. #6
    Join Date
    Jun 2003
    winter park, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well rerun today DAVIS ABC fuel10x6 wood master air screw9200 wood XOAR 10x5 11200 IDLE IN BOTH 2900-300O no bogs to WOT needle 1 to 1 1/4 open on needle
    my guess a apc grey prop 10x6 should give an other 500 on the revs
    a little disappointed in the 10x6 revs - good points- quiet, very light grey smoke, very little oil out and light color not black martin
    interesting the K and B 20 also did 9200 on the 10x6 wood prop so did the irvine 20 -9200 on the 10x6
    Just cranked it up again to try the grey nylon taipan prop that Fiery sent me they have a big rear overhang ( no issue) fairly wide blades 9x6 11000
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
