Tadpoles
RE: Tadpoles
A lowly VMAR "Arrow Tiger" ARF pattern trainer.
55" span. Symmetrical airfoil.
Shape reminds me of 'half-half' P-51D Mustang and Bf 109-G Messerschmitt.
Still available.
http://www.levelflight.com.au
This business also sells ENYA 2 and 4 stroke diesels. A big plus from me for that.
I have just bought a VMAR Scottish Aviation "Bulldog" for an Easter 2013 Build, to be powered by a diesel 10 cc. Build and wood quality is much improved.
It's no 'World Models' ARF, but excellent value for the price.
Apologies ... I am a long way off Micro-diesels.
Still available.
RE: Tadpoles
Fiery have several VMARs the Apache ll and lll among them the apache ll has been around a long time sturdy build had an Irvine 40 diesel then a upgrade to Irvine 53 Davis head
on the 53 it will knife edge also the hot rod high wing the apache lll has a side mounted 52 4strk ASP and cowled in to get a way from the trainer look also a low wing arrow 40 size
think it is a VMAR and an other high wing Hot Rod I have no beefs with VMAR qualitythey had some issues years ago but no more, at least in the last 10 years martin
Post Note I do have an ASP/MAG 4 strk converted to Diesel by Greg Glamryz that I can swap in
1 Post
RE: Tadpoles
But I'm OT!..............10,050rpm on a Cox 5x3 yellow this morning-unfortunately the camera batteries went flat when I tried to get the tacho shot........more to come. The Cox 5x3 still represents a significant load compared to other 5" props such as the Topflite or DC 5-1/4x3-1/2, so the performance continues to impress. Engine sounded very happy running this prop-but definitely harder to start.
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
RE: Tadpoles
Over 10,000 RPM on a Cox 5 x 3?
Now I really want one! I have a box of those Topflite 5 1/4 x 3 wood props too ...
As you said Chris, lesson learned.
#31
1 Post
RE: Tadpoles
It took a bit of tweaking to get it there, but we made it in the end. Camera batteries currently on charge, so I'll try and get a repeat run later-but its getting warm here today and it may not be so happy-we'll see.
Eventually I will run it on the raft of small props I've carefully balanced and we'll have some reasonable figures for reference. I won't do the APC ones though-as they'll need a bushing machined up, and I'm too busy with my Nats preparations. Perhaps early in the New Year, after I've returned from down south.
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
#33
1 Post
RE: Tadpoles
Well how much you'll eventually see once I run a series of comparative tests of the same props on the mini ED Baby of the same size..........but I need to make a compression screw lock for that one
CJM
CJM
#34
1 Post
RE: Tadpoles
'ere we are then-10080rpm, proof positive............
CJM
.....a quick check on the calculator suggests that this equates to ~0.013 BHP.......there may be a bit more to be got from the engine yet
CJM
#35
RE: Tadpoles
Chris
Is it able to drain it's tank yet on a given needle setting? Or leaning out and quitting?
Now the Schlosser .25 cc's are also historical artifacts. it looks like I will have to keep my eyes open to see if one comes up on *bay.
#36
1 Post
RE: Tadpoles
It still gets hot and labours to a stop unless you back off comp and richen the needle after about 1-1/2 minutes running-I've probably managed to run the tank dry twice in about a dozen separate runs. The shaft is a beautifully free fit in the main bearing so I'm assuming its cylinder friction is the issue here. I also noted today that the contra seems to freeze after more than a couple of minutes running [for the run where I took the photo, I topped the tank back up from nearly empty whilst it was still running-so that was a longer run than usual-and found that I couldn't back off the comp once the engine started to labour.
One thing I'll say for the wee beastie-you can tell whens it's happy.........and you can definitely clearly hear when it's unhappy........
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
#37
RE: Tadpoles
It has a nice tight P/L fit - check.
It has a contra that 'locks up" when really hot - check.
These are plus points. I dislike engines that are a "loose" piston fit out of the box, and diesels with leaky contras are annoying.
The issues will only improve with running time, which is a bonus with a diesel this small.
