Everything Diesel Discuss R/C Diesel engines here.
PAW 06 fuel draw question
Reply
Old 01-20-2013, 01:08 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PAW 06 fuel draw question
OK group Have started the Polk tiger moth with the PAW 06, really cannot pressurize the tank with a fitting on the muffler such as other engines
Do you think the PAW will have a problem if fuel pickup in tank 3/4" below carb center
If has to go up will require quite a bit of work to modify fus. to do this, to get tank higher if we do we do but would like to avoid martin
AMB is offline
Old 01-20-2013, 01:24 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: PAW 06 fuel draw question
I may just put the engine back on the bench lower the tank 3/4" and see what happens just thought of this martin
AMB is offline
Old 01-20-2013, 01:42 PM
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It should be fine, low end might get a little lean at the end of a run but diesels don't stop as easily as glow engines do.
Mr Cox is offline
Old 01-20-2013, 02:09 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mr Cox THX to get the tank higher would have to do a total rebuild front of the plane cut off the whole top forward of the windscreen to firewall and its glued over a piece of curved foam
martin
A 2oz tank for an 06 is big, would most likely fly off only about 1/2 before landing and refueling
AMB is offline
Old 01-20-2013, 02:23 PM
greggles47
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Martin,
What about an external FF style tank.
Dave Owen lists them, sorry I can't extract the pic but here's the link. http://oea.modelenginenews.org/pricelist_2011-04.pdf
Greg
greggles47 is offline
Old 01-20-2013, 02:59 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Greg that is a thought a couple of rubber bands and I would be in biz martin
AMB is offline
Old 01-20-2013, 03:21 PM
Recycled Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here you go Greg.
Recycled  Flyer is offline
Old 01-20-2013, 03:27 PM
Recycled Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: AMB
Martin,
from the PAW web site-
"Fuel level in tank during starting procedure MUST NOT BE HIGHER than in the same horizontal plane as jet. A little lower (up to 1cm) is alright. "
As to pressuring the fuel tank have you looked at crankcase pressure? Perhaps the back plate is thick enough to accept a pressure nipple.
P.S. just looking at your other post on this it would seem that you have quite a bit of tank space behind the engine on the radial mount .
Old 01-20-2013, 03:58 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Greg pulled backplate very thin a no go on that one, one other thought smaller tank, whats the approx run time on the PAW 06 on one oz fuel martin
guess at least 10 minutes at around 10K
guess I could go to the source and call PAW
AMB is offline
Old 01-20-2013, 04:13 PM
fiery
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One of these would make a nice tank ... if the bung can take diesel fuel
http://www.ebay.com/itm/390403868791...84.m1423.l2649
fiery is offline
Old 01-20-2013, 04:39 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK Hayes does make a 1 oz round tank #s 077 ok fro diesel of course as is martin
whoops header tank will it work on its own??
it should orient so tubes are vertical bottom plugged anyhow , center draw on clunk line upper vent just lead higher than tank (vent ine)
Fiery cheap too only $4 the E bay one twice the price THX for the search and check
AMB is offline
Old 01-20-2013, 05:45 PM
steve111
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For what it's worth, I had one in a little CL stunter. It would still draw quite ok with the nose pointed straight up, and the pickup a good 2 1/2 or 3 inches below the level of the spraybar.
steve111 is offline
Old 01-20-2013, 05:48 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steve THX you just relieved my anxiety on this one martin
I really did not want to do a hack thing on the moth plenty of room for the 2 ouncer just need a little opening up on the bulkhead wit dremel and drum sander on it
AMB is offline
Old 01-20-2013, 07:08 PM
Recycled Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Steve,
what was the inverted stunt run like with the spray bar now 2 1/2 inches below the fuel feed pipe?
Old 01-20-2013, 07:29 PM
steve111
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Chris, I think you've misunderstood me. I was referring to when the nose was pointing straight up. Inverted, the pickup is naturally level with the spraybar again.
steve111 is offline
Old 01-20-2013, 07:30 PM
Recycled Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gottcha! Thanks.
Reply
Display Modes
