If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    nitroairplane's Avatar
    Join Date
    Feb 2011
    London, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Little Valentine gone wrong
    Hello guys These last couple of days I've been going through what little I have left of my collection, most of the remaining engines have had a go in the stand following a good clean and lube.
    I ran a load of the little fellas too, the AEs, Bambi, AH, etc and then I go to one of my little Valentines and as soon as I took the back plate off I sa that not only had the conron bent but it looked like it had been mutilated too.
    This was a great little engine and had powered a couple of models before so I was gutted to see that probably my most friendly small diesel was broken.
    I have no idea how this could have happened because it's never stopped abbruptly, locked up or been in a crash. Certainly nevr been touched by an electric started.
    If anyone has an ideo how this could have happened it'd be great to hear.
    I am writing an email to Ron right now to look for a replacement part.
    Pics coming soon.
    Thanks guys
    Indra
    A NOSE HEAVY PLANE FLIES BADLY A TAIL HEAVY PLANE FLIES ONCE!!!!
    http://www.youtube.com/user/nitroairplane?feature=mheehttp:
  2. #2
    Join Date
    Feb 2007
    , MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Little Valentine gone wrong
    Any luck with getting support from Valentine?
    If your engine has powered a model you ought to be treated like some kind of factory supported superstar-nobody ever even runs these things-I'm of the opinion that they are mostly meant to be looked at and fondled.
    When you get the engine back, check the skirt of the cylinder for interference-the impact marks were likely from the bending of the rod though.
  3. #3
    Join Date
    Feb 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Unfortunately I've not no response so far but that doesn't particularly worry me because he has been a little slow to reply to emails before.
    This engine spent a small time in an FMK rainbow .010 stik type kit before making it's way into the tom thumb with a parkzone brick radio and servo boar, that was a lovely plane to fly and it only came in at around 2.5oz ready to fly.
    It would take off from the smoother dirst runway with it's little balloon wheels, the engine had a fair amount of runtime on it and it always ran well.
    The way I see it is that if they run well then why not let it see the air and have the memories other valentine engine owners won't?
    It's always just as good to look at when/if it wears out and you can have storie to tell about it, it's just a RoVa so nothing with too so special I wouldn't fly it, I'd be damn upset to have a flyaway
    still nowhere near as upset as I'd be if it was the mini bee.
  4. #4
    Join Date
    Feb 2002
    Hervey Bay Queensland, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Indra
    Are you able to post a photograph of your bent conrod?
    If you have no luck with a reply, and the engine still has an acceptable piston/liner fit, I am certain someone can make up a new conrod using an alloy that will not bend so readily.
    A while back I emailed Mr Valentine using the link given on his site. I never did receive a reply. So, I made other arrangements.
  5. #5
    Join Date
    Feb 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Luckily I got an email from Ron this afternoon (UK time) saying he man have one in stock so I will see about that first
  6. #6
    Join Date
    Feb 2007
    , MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: fiery
    Indra
    Always better to bend a rod on an obscure engine than break a crank..... Much easier to make the rod out of something that will give than something that won't. I made this point with Rocket Rob when we got our Schlosser .25's and joked about making them out of Titanium-I'd rather bend a tiny bit of aluminum than have to fixture, machine, heat treat, and grind a shaft.
  7. #7
    Join Date
    Sep 2005
    Infront NSW, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If the rod's bent then it may be a good idea to check the crankpin alignment as well.
    Just say'in.
    Ray
  8. #8
    Join Date
    Feb 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good point on the conrod material. I expect the shafts, crankwebs, crankpins and piston bosses on these little ones may not be particuarly sturdy. The rod is the best "weak point".
    Here is the 0.006cc (0.00037 cu. in.) Valentine "nano bee". It's conrod must be the diameter of a sewing needle [X(]
    http://www.ebay.com/itm/Rare-Valenti...item5aef938fbc
    Has anyone ever seen one run?
  9. #9
    Join Date
    Feb 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey guys
    I exchanged a few emails with Ron and he said I could send it to him to be checked and for a new con rod free of charge.
    I'm off away for the weekend but I'll be sending I back to him on Monday.
    Fiery:
    The nano bee is quite the work of art, I never owned one but did have a mini bee 0.021cc and a blitz 0.05cc as well as the 0.098cc ones.
    I ran both once just to show myself that it was possible.
    When this little beauty is up and running again I'll get a vid of it both in the stand mad maybe in the air
    Cheers guys
    Indra
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
