Hyper critical compression setting????
Hello All:
I attempted to fly one of my ST G20/.15D engines yesterday and I found that the compression adjustment was very critical! It was difficult to adjust the needle valve and compression to obtain a good setting.
I made no adjustments to the engine or fuel since the last time that the engine had been flown. What gives? I am running an 7x6 wooden prop. Perhaps I need to place a larger load on the engine?
Tia,
Frank McCune
Tia,
Frank McCune
Whenever I have problems starting the engine or setting the needle or compression, I switch to a new can of fuel. If it starts and runs differently (better), then I go on to assume that some of the ether has gassed off from the fuel. A small squirt of ether in the old can makes it run much better.
Can you smell ether coming coming from your fuel cans when tightly capped?
Reply ro Quick Sport
Hi:
Thanks for the prompt reply!
No, there is no smell emitting from my fuel bottle. This fuel works very well In my other Diesels. The engine starts very easily but the compression adjustment is very sensitive to a point where I have a difficult time going from over compressed to under compressed very quickly. I am planning to use a larger heavier prop the next time I run the engine. I think that more load there is on the engine, the less critical the compression is to adjust for best results. I will keep you posted.
Be well,
Frank McCune
Be well,
Frank McCune
Hi:
Be well,
Frank McCune
Be well,
Frank McCune
Indeed a larger prop will make the compression setting easier to get and less fussy. Too small a prop can be problematic, however if the fuel itself is of the wrong mixture, you may find yourself in the same boat. By his I mean perhaps the engine needs more ether? Ignition improver?
Maybe it's just clapped out.
As with many things, too much or too little of a good thing isn't all that good. I am not familiar with the ST G20/15D - is it an ABC construction? Ferrous? I'd assume it's not ringed..
It's a lapped Iron Piston in a Steel Liner twin ball race racing engine that originally came out in the early 1960's. Makes a nice control line sports engine. They were still available over the counter in the 1980's. Still some of 'em will be pushing sixty years old, so they might be a bit tired.
Hi All:
Today I had Diesel engine problems all day! The weather was 83 F and I had a problem with my .40 going lean. A friend of mine from the Ukraine suggested that it was just too hot to run a Diesel. I had three other Diesel Experts from around the world helping me but we could not get in a full flight. The engine was set a bit rich and with the compression just advanced enough to where the engine was mo longer misfiring due to insufficient compression. After about two minutes of flying, the engine would really start turning a high speed. It was soon after this, the engine became so over compressed that I had to dump it on the grass to prevent engine damage. This happened each flight.
If I launch when the engine is misfiring due to low compression, it never speeds up enough to a point where it runs without misfiring, under compressed.
Today is the first time that I flew this engine in hot weather. I never had to adjust it when flying in the Spring and Fall so temperature must be to blame. My ST G 20 /15D also ran poorly with the same symptoms. Both engines started very easily so the fuel must be fine. It is the same fuel that I have been using for awhile. I will mix some new fuel and see if my problems disappear!
The .40 engine is an OS FP with a DDD conversion head. The fuel is a good mix with plenty of castor oil.
Due to the fact that Diesel fuel is so very expensive to mix and the .40 drinks it like a fiend, I think that I will install the original glow head and save the Diesel mix for the .15 engines. Lol
Thoughts and/or comments?
Tia,
Frank McCune
Tia,
Frank McCune
Hello All:
Tia,
Frank McCune
Tia,
Frank McCune
