Everything Diesel Discuss R/C Diesel engines here.
D-C Sabre, 1.5 cc diesel
Reply
Old 12-06-2017, 07:38 PM
Ultracon46
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Angry D-C Sabre, 1.5 cc diesel
I have an old D-C Sabre diesel I am trying to resurrect. Worst problem I have is the seized prop spinner nut. The engine comes with a red metal spinner which is the prop nut. It has a hole drilled through it so you can tighten and loosen it with a small metal rod. I used to use a small screwdriver with the head cut off. The darn thing seems welded to the crankshaft and when I turn it using a screwdriver it just turns the engine over. That sucker is tight! Can anyone give me some help on undoing this thing? Have tried a heat gun, Marvel Oil, 3-in-1, 10% nitro fuel, acetone and WD-40. All to no avail. Help!!
Ultracon46 is offline
Old 12-07-2017, 12:20 PM
fiery
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Soft jaw vice grips to hold the shaft?
fiery is offline
Old 12-07-2017, 01:07 PM
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A zip tie through the exhaust, then heat up the spinner with a small torch and see if it comes loose...?
Mr Cox is offline
Old 12-07-2017, 01:13 PM
Ultracon46
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great idea! Thanks!
