Everything Diesel Discuss R/C Diesel engines here.
What's the attraction of diesel plane engines?
Reply
Old 04-28-2018, 05:24 PM
N99JH
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by 1QwkSport2.5r View Post
Ringed engines should NEVER EVER be used as Diesel conversions in the air. IMVHAIO. Ringless pistons are the proper way to go as is the proper fuel. Synthetic oils have NO place in model diesel fuels. Set the engine right and you shouldn’t have to do much to it for a long time. Carbon buildup in a short period of time causing the engine to not run properly leads me to believe either improper engine settings or incorrect fuels being used. IMO.
And how much actual flying experience do you have if you don't mind me asking?
N99JH is online now
Old 04-28-2018, 05:38 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Enough to know ringed engines suck as Diesels.
1QwkSport2.5r is offline
Old 04-30-2018, 10:46 AM
HW50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Back in the 60's diesels up to .15 (or 2.5cc) rarely had problems other than to those who didn't like the smell. At the time we thought bigger engines like 3.5cc upwards would not be very suitable due to the vibrations that came with increased size. The really big engines that came to use later on, often with a piston ring, is yet another matter.
So for smaller CL engines, I think diesels are really good fun. No carbon problems that I know of. The combat and team race diesel powered models have shown us how powerful these little engines can be.
Maybe the diesel concept is best suited for the smaller engines?
HW50 is offline
Old 04-30-2018, 12:37 PM
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I spoke at length with Dave Platt about his diesel experience. He grew up flying diesels (mostly Oliver/Tiger) in Great Britain and it is my impression he is/was quite well-versed in them. Back when he was competing at the highest levels of RC Scale, he was campaigning a T-28 in which he had installed a Moki 1.8 2 stroke glow. However, he wanted to spin a large 3 blade prop and also to have the engine fully enclosed and was worried about over-heating a regular glow engine under these conditions... So he converted the big Moki to diesel. In our conversation he told me he could never get the engine to run well enough to use in this application; he tried different fuel mixes and carburetion and finally gave up, converting back to glow.
It seems some engines just make bad diesel engines.
My experience has been that you probably cannot go wrong with a P.A.W.
They may not be the most modern powerplant, but they are designed from the ground up as diesels, and have many years of successful diesel experience behind their construction.
Picking the correct type of model and flying style is also integral to "success" with a diesel.
RichardGee is online now
Old 05-01-2018, 02:06 AM
N99JH
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All of my experience is with Davis Diesel conversions and I used his fuel. I adjusted the engines per his instructions and never ran them over-compressed. Simply put - no matter what I tried, it did not work. Plain and simple!
N99JH is online now
Old 05-01-2018, 03:11 AM
  #31
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used Davis conversions as well. I did not adjust the engines his way nor did I use his fuel. I mixed my own fuel and used tuning advice from a friend. I run my conversions slightly rich of peak and adjust the compression accordingly.
My fuel was 31% ether, 23% castor oil, 2% Amsoil cetane boost, balance JetA or Kerosene. Works every time without any poor habits or side effects. Davis fuel has synthetic oil in it which IMO is not a good choice to make. Model engine synthetics do not have the pressure properties that castor does and likely why more of the oil burned than blowing out the exhaust. IMO based on speculation and no pictures.
Old 05-01-2018, 09:01 AM
  #32
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any idea where we can acquire the ingredients for model diesel fuel? Amyl Nitrate and Ether are the real challenges. Have you ever substituted an auto diesel Cetane booster and John Deere Staring fluid, respectively?
Old 05-01-2018, 10:54 AM
  #33
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The best is to get ready-made fuel, rather than experimenting with different blends. What has worked well for 70 years will still work well....
Doesn't Davis Diesel Development provide fuel in the US for instance?
Mr Cox is offline
Old 05-01-2018, 11:02 AM
  #34
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The only source for Davis fuel is Tower Hobbies...where is it perpetually on back-order.
FHS (Red Max) was another source - not any longer.
Aerodyne (British I think?) also not available.
Home brew seems to be the only option; ether and amyl nitrate are impossible to obtain in many places.
Old 05-01-2018, 11:36 AM
  #35
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use John Deere starting fluid and Amsoil Cetane Boost for my fuel and it works identically to Davis fuel as far as power and starting/handling goes. I do not have excessive carbon build-up either.
I mix my own diesel fuel because it’s about 60% cheaper to do so as well as the fuel has exactly what I want in it at the proportions I want. Davis fuel costs about $15 per quart plus shipping. My fuel costs me about $6-7 per quart to make myself.
Old 05-01-2018, 08:36 PM
  #36
fiery
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A big 10 c.c. Russian Zeus and a big fan up front ... a Bolly Clubman 13.5 x 6. Old OS .25 FSR carb. Conversions are great if the base engine is built to take the extra strain and the conversion head is properly engineered.
fiery is offline
Old 05-01-2018, 08:46 PM
  #37
fiery
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ringed engines suck as a diesel? No-one told that to this nice Webra Speed .61.
Delay in starting was due to my not advancing compression. Once I did that it fired right up.
fiery is offline
Old 05-02-2018, 01:45 AM
  #38
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I’ve run ringed Diesels too. They don’t hand start for beans, and seemed finnickier to adjust. The ringless engines seem 10X better and easier to handle, so I dumped the ringed ones or converted them to ABC. I recently converted a ringed ST .51 to ABC with a piston/liner from a Tiger Shark .52. I haven’t run it as a Diesel yet, but I intend to. My benchmark 7.5cc prop is an APC 13x6, which an ST GS.45 ABC can do around 10,800+. I’d think a 13.5x6 would be a little small for a .61?
Old 05-05-2018, 02:30 PM
  #39
ebeneezer3
ebeneezer3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John Deere starting fluid is 80% ether. I believe it's the best you can get.
ebeneezer3 is offline
Old 05-05-2018, 03:47 PM
  #40
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It’s near 100% when you remove the propellant. It’s 80% ether and 20% propellant. I treat it as pure ether and my fuel matches Davis Diesels fuel in rpm from the same engine. I actually get more power in some cases.
Old 05-05-2018, 03:53 PM
  #41
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Fox .74 w/Davis head
Old 05-05-2018, 05:08 PM
  #42
N99JH
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What percent of each are you using? Is the balance pump Kerosene? Can you please share your home brew formula? I would love to try it.
N99JH is online now
Old 05-08-2018, 10:22 AM
  #43
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
31% John Deere ether, 23% castor oil, 2% Amsoil Cetane Boost, balance pump kerosene or Jet A.
Old 05-12-2018, 11:24 AM
  #44
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you know if ANY Castor oil will work? For example, WalMart sells a 16 oz. bottle of cold pressed Castor oil. Will this work for mixing fuel?
Old 05-12-2018, 03:30 PM
  #45
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As long as it contains no additives. Check the label. Larger quantities is cheaper though. I get a gallon for $17+shipping. Usually around $22-25 shipped. Last time I bought an 8oz bottle it costed $5 at Wally world. For mixing large amounts of fuel, it’s impractical to use such small quantities.
Old 05-13-2018, 11:55 AM
  #46
triumphman49
My Feedback: (149)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great thread and have certainly enjoyed reading this. Not a lot of experience here, but years ago have run a 40FP w//DDD on stand. After a long break, and having accumulated numerous DDD heads for mostly K & B engines, have a MVVS .61 and factory diesel head which I'm hoping to install in a J3 Cub. Maybe a 16" prop will be about right. Tried to check for DDD fuel at TH, but unable to access it. All Things change, don't they!
Thanks again
triumphman49 is offline
Old 05-14-2018, 05:32 AM
  #47
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks again
Have you run the MVVS .61D yet?
Old 05-14-2018, 03:04 PM
  #48
triumphman49
My Feedback: (149)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, Haven't run it yet. Just received the .61 last week and there is a strong push for hours on my construction job. Also will have to brew the fuel. Thanks for asking.
T-man 49
Old 05-15-2018, 03:36 AM
  #49
controlliner
controlliner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What paint is that O_O. I'm mesmerized.
Jim West
controlliner is offline
Old 05-15-2018, 07:15 AM
  #50
RichardGee
My Feedback: (156)
RichardGee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim West
I used VHT hi temperature (650 deg. F) "copper"
Mother's Mag Aluminum polish on the shiny areas.
Drilled a hole through the hex head of a longer compression adjustment screw and silver soldered a copper T bar. Hi temp black applied to the screw.
